X motor not working is it a board issue?
August 04, 2015 02:12PM
Got a new Folger tech 3D print with all the head aches that comes with it.After about a mouth later and less then a week of working on it I'm still not up and running but very close.
'I think the issue is board related or program(more board) My X motor doesn't move using the manual controls in the Repetier host program and I get an line error of some sort no idea what it is. I have switch my X motor with the Z motor and the issue is not motor. Any ideas thanks
Re: X motor not working is it a board issue?
August 04, 2015 02:54PM
Seems like a lot of headaches come from those folger tech printers. Anyway, have you tried moving the Z motor by plugging it into the X to confirm it isn't a bad driver, does your motors move when they are homed, and lastly what error are you getting?
August 04, 2015 04:38PM
Yes I switch plugs, step drivers ( all 5 of them none changes out come) and even the motors with the same results. the motor works on Y and Z and any of them in X doesn't work. the x moves a quarter inch at a time until it hit the switch then it will not go back.
So at this point I know the motor works and the step drivers are good. I also switch plugs so I know that isn't the issue. So I'm down to 2 possible problems one being program witch I don't think is the problem since this is not the first time folger tech made this printer.So that leaves the board, not sure if its the Arduino clone (which I already had to get a new one (works as far as I know)) or the ramps 1.4 board.
Here a copy paste of the Repetier Host connection info (look for the line with " Error:Line Number is not Last Line Number+1, Last Line: 0" there are a few of them:
15:21:13.131 : OpenGL version:4.4.0
15:21:13.131 : OpenGL extensions:GL_AMD_multi_draw_indirect GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_query_buffer_object GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shader_image_load_store GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_bindless_multi_draw_indirect GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_ARB_sparse_texture GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NV_shader_thread_group GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
15:21:13.131 : OpenGL renderer:GeForce GT 520/PCIe/SSE2/3DNOW!
15:21:13.131 : Using fast VBOs for rendering is possible
15:21:19.574 : Printer reset detected - initalizing
15:21:19.621 : start
15:21:19.621 : echo:Marlin 1.0.0
15:21:19.621 : echo: Last Updated: Aug 1 2015 5-20-15 12:43:49 | Author: (FOLGER TECH, 8 i3 Prusa Config)
15:21:19.621 : Compiled: Aug 1 2015
15:21:19.621 : echo: Free Memory: 4519 PlannerBufferBytes: 1232
15:21:20.136 : N1 M110 *2
15:21:20.136 : N2 M115 *4
15:21:20.744 : N4 M111 S6 *67
15:21:20.791 : N5 T0 *31
15:21:21.977 : echoconfused smileyD init fail
15:21:22.023 : echo:Unknown command: ""
15:21:22.023 : ok
15:21:22.023 : Error:Line Number is not Last Line Number+1, Last Line: 0
15:21:22.023 : Resend: 1
15:21:22.039 : N6 M20 *55
15:21:22.039 : ok
15:21:22.039 : Resend: N1 M110 *2
15:21:22.039 : Resend: N2 M115 *4
15:21:22.039 : Resend: N4 M111 S6 *67
15:21:22.039 : Resend: N5 T0 *31
15:21:22.039 : Error:Line Number is not Last Line Number+1, Last Line: 0
15:21:22.039 : Resend: 1
15:21:22.055 : ok
15:21:22.055 : Resend: N1 M110 *2
15:21:22.055 : Resend: N2 M115 *4
15:21:22.055 : Resend: N4 M111 S6 *67
15:21:22.055 : Resend: N5 T0 *31
15:21:22.055 : Error:No Line Number with checksum, Last Line: 0
15:21:22.055 : Error:Line Number is not Last Line Number+1, Last Line: 0
15:21:22.055 : Resend: 1
15:21:22.070 : ok
15:21:22.070 : ok
15:21:22.070 : Resend: N1 M110 *2
15:21:22.070 : Resend: N2 M115 *4
15:21:22.070 : Resend: N4 M111 S6 *67
15:21:22.070 : Resend: N5 T0 *31
15:21:22.070 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[www.mendel-parts.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:FolgerTech EXTRUDER_COUNT:1
15:21:22.070 : ok
15:21:22.148 : ok
15:21:22.148 : echo:Active Extruder: 0
15:21:22.148 : ok
15:21:22.148 : Resend: N6 M20 *55
15:21:22.148 : ok
15:21:22.148 : N7 M80 *60
15:21:22.148 : N8 M220 S100 *73
15:21:22.148 : N9 M221 S100 *73
15:21:22.148 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[www.mendel-parts.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:FolgerTech EXTRUDER_COUNT:1
15:21:22.148 : ok
15:21:22.148 : ok
15:21:22.148 : N10 M111 S6 *118
15:21:22.148 : ok
15:21:22.148 : N11 T0 *42
15:21:22.148 : N12 M220 S100 *114
15:21:22.148 : Begin file list
15:21:22.148 : End file list
15:21:22.148 : ok
15:21:22.148 : ok
15:21:22.148 : N13 M221 S100 *114
15:21:22.148 : N14 M111 S6 *114
15:21:22.148 : ok
15:21:22.148 : ok
15:21:22.148 : N15 T0 *46
15:21:22.148 : ok
15:21:22.148 : ok
15:21:22.148 : ok
15:21:22.148 : ok
15:21:22.164 : ok
15:21:22.164 : echo:Active Extruder: 0
15:21:22.164 : ok
15:21:23.396 : N1 M110 *2
15:21:23.396 : N2 M115 *4
15:21:23.396 : N3 M111 S6 *68
15:21:23.396 : N4 T0 *30
15:21:23.396 : N5 M20 *52
15:21:23.412 : ok
15:21:23.412 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[www.mendel-parts.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:FolgerTech EXTRUDER_COUNT:1
15:21:23.412 : ok
15:21:23.412 : ok
15:21:23.412 : N6 M80 *61
15:21:23.412 : echo:Active Extruder: 0
15:21:23.412 : N7 M220 S100 *70
15:21:23.412 : ok
15:21:23.412 : Begin file list
15:21:23.412 : End file list
15:21:23.412 : ok
15:21:23.412 : N8 M221 S100 *72
15:21:23.412 : ok
15:21:23.412 : ok
15:21:23.412 : N9 M111 S6 *78
15:21:23.412 : ok
15:21:23.412 : N10 T0 *43
15:21:23.427 : ok
15:21:23.427 : echo:Active Extruder: 0
15:21:23.427 : ok
August 04, 2015 07:15PM
FYI I updated firmware but not change.
