Re: My extrusion is wavie August 16, 2015 01:56PM |
Re: My extrusion is wavie August 17, 2015 01:14PM |
Re: My extrusion is wavie August 17, 2015 07:57PM |
Re: My extrusion is wavie August 17, 2015 08:50PM |
Putzer
You need to get rid of the wavy problem before anything else. Do an extrusion calibration. I find pronterface easy. Mark 100mm of filament and then extrude 100mm and measure. It should be 100mm into the extruder. The extrusion should be smooth with the same thickness. What speed are you printing at? I fine 25 the best. I had a small banding problem at .2mm but went away at .3mm layer height. Had minor defects in the first couple of layers but went away using a raft. Printing ABS with head temp of 240C and bed of 95C and prints are nice and smooth.
Re: My extrusion is wavie August 18, 2015 12:42AM |
Re: My extrusion is wavie August 18, 2015 01:31PM |
Re: My extrusion is wavie August 18, 2015 02:34PM |
Re: My extrusion is wavie August 21, 2015 01:02PM |
Re: My extrusion is wavie August 21, 2015 02:33PM |
Re: My extrusion is wavie August 21, 2015 03:48PM |
Re: My extrusion is wavie August 21, 2015 07:14PM |
