SO
The problem is not the extruder motor but maybe my DRV8825 stepper driver. I am set to 1/16th.
Any Ideas?
If whatever axis you plug the stepper into doesn't work it is most likely the driver or the tuning of it.
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
I exchanged the stepper driver board and still get the same, this time the voltage is set to 1.67 and I can feel the extruder motor humming. When I look at the gears inside they do not move, or maybe barely..
This must be sort of normal maybe because I am controlling it through manual control. So I am limited by to short extrusions at a time.
Did you heat up your hot end to be at least 170'c?
Just a thought... maybe you've tightened the hobbed bolt down to tight.
@sarf2k4
The hot end is heated to 220 Celsius, but I am not testing with filament, just trying to watch the gear move. Ill try loosening the hobbed bolt, or at least what I think is the hobbed bolt.
