huge problem. I've got smoke. August 19, 2015 09:49AM |
Re: huge problem. I've got smoke. August 19, 2015 10:12AM |
Re: huge problem. I've got smoke. August 19, 2015 10:42AM |
Re: huge problem. I've got smoke. August 19, 2015 11:32AM |
Re: huge problem. I've got smoke. August 19, 2015 11:58AM |
Re: huge problem. I've got smoke. August 19, 2015 12:22PM |
Re: huge problem. I've got smoke. August 19, 2015 12:56PM |
Re: huge problem. I've got smoke. August 19, 2015 12:58PM |
Re: huge problem. I've got smoke. August 19, 2015 01:45PM |
Re: huge problem. I've got smoke. August 19, 2015 05:44PM |
Re: huge problem. I've got smoke. August 19, 2015 05:51PM |
Re: huge problem. I've got smoke. August 20, 2015 02:08AM |
Re: huge problem. I've got smoke. August 20, 2015 07:53AM |
Re: huge problem. I've got smoke. August 20, 2015 01:25PM |
Re: huge problem. I've got smoke. August 20, 2015 03:00PM |
Re: huge problem. I've got smoke. August 20, 2015 03:05PM |
Re: huge problem. I've got smoke. August 20, 2015 03:22PM |
Re: huge problem. I've got smoke. August 20, 2015 04:05PM |
Re: huge problem. I've got smoke. August 20, 2015 04:29PM |
muntahunta
just read all of that and I have checked the "chip" next to the power input on the mega and it is indeed fried... however I am certain that I have my wiring correct. and also, wouldnt the ramps still work by itself?
What do i need? a new ramps? a new mega? both? a wiring guide that isnt going to blow up yet another part?
Re: huge problem. I've got smoke. August 20, 2015 04:39PM |
Re: huge problem. I've got smoke. August 20, 2015 05:00PM |
muntahunta
I tried this before posting here.
He says that to test using the lcd (giving a white screen) that the USB power isn't enough, which is the reason i tried to connect the power, nothing happens when connecting the power.
with just USB I get the same white screen he gets, but that could be due to lack of power from USB in comparison to the PSU. So I cant use his testing method unless I have the power supply to work with, but it seems to not be working at all.
Do you own a multimeter to check the power supply output? Maybe a 12v light bulb?
Re: huge problem. I've got smoke. August 20, 2015 05:04PM |
Re: huge problem. I've got smoke. August 20, 2015 05:11PM |
muntahunta
i dont own a multimeter, but since i plan on expanding my amount of printers to 5+ eventually, it may be a good tool to have.
as for a 12v lightbulb.... im not a lightbulb expert in any way, but im from the UK and im sure bulbs here are rated in watts. why, do you have an idea? (idea, lightbulb, ding.... ill leave now)
Re: huge problem. I've got smoke. August 20, 2015 05:29PM |
Re: huge problem. I've got smoke. August 20, 2015 05:36PM |
muntahunta
The power supply is fine and working but I think you may have possibly solved the problem... I checked the power supply and its a 12v 15A.... Obviously it needs 16A, but surely this wouldnt give much problem if there is literally NOTHING plugged in other than the RAMPS?
Re: huge problem. I've got smoke. August 20, 2015 05:42PM |
Re: huge problem. I've got smoke. August 20, 2015 11:57PM |
Re: huge problem. I've got smoke. August 21, 2015 02:15AM |
