(Noob) Need help with first time prusa i3 questions !! August 31, 2015 11:08PM |
Re: (Noob) Need help with first time prusa i3 questions !! September 01, 2015 06:34AM |
Re: (Noob) Need help with first time prusa i3 questions !! September 01, 2015 07:58AM |
Re: (Noob) Need help with first time prusa i3 questions !! September 01, 2015 10:54PM |
[email protected]
I'm partial to Folger tech mostly due to the metal frame acrylic cracks easy when over tightened and can flex messing with the print.
[www.ebay.com]
Re: (Noob) Need help with first time prusa i3 questions !! September 01, 2015 10:56PM |
sarf2k4
First of all, there are no fake nor legit since repraps are open source, if you're saying about legit design as in the first prusa i3 design; box frame design, sunhokey or geeetech would match that, while in the video, it would be hephaestos, replikeo or prusa i3 rework series.
If want something simple go for rework or folgertech 2020, easy to assemble from my observation, I own geeetech i3b, I somewhat satisfied with it because its design by having adjustable z endstop trigger and their custom made printed parts that doesn't require much tinkering to hit the endstops. Their stock hot end design accommodates low profile design, you can get a very high z axis range also might able to hit 200mm max, mine I limited it to 180mm high only
In overall, this would depends on what what kind of design you want, electronic, frame material, hot end provided, bowden/direct drive type. If you don't care about the prusa material type, two thing I can give you tips; go for ramps 1.4 electronics, and observe the structural design for acrylics, most acrylics are 6mm even the main frames, but geeetech provides 8mm thick especially on main frames. Still acrylics can break anytime if you're not careful
Re: (Noob) Need help with first time prusa i3 questions !! September 02, 2015 06:49AM |
watlooazn
[email protected]
[www.ebay.com]
Thanks ! Is there anyother other than tools and fillament that I need to purchase myself for this link? How was the build? Were all the google drive docs sufficient? Would you recommend this kit?
Re: (Noob) Need help with first time prusa i3 questions !! September 03, 2015 05:13AM |
Re: (Noob) Need help with first time prusa i3 questions !! September 07, 2015 06:17AM |
