Top layer not printing properly September 03, 2015 02:00PM |
Re: Top layer not printing properly September 03, 2015 02:10PM |
Re: Top layer not printing properly September 03, 2015 02:47PM |
Re: Top layer not printing properly September 03, 2015 02:51PM |
Re: Top layer not printing properly September 04, 2015 01:56AM |
Thanks, it was actually a temperature problem. Increased it by +5 and it came out goodQuote
imqqmi
Could be temperature related,try +10 degrees, could be pressure of the nozzle, check if there's no leak near the heater block.
Top layers usually print slower, is it related to the extruder motor not being able to run slowly? Does is skip or not run slowly? It could be the current is not enough or that the stepstick needs to run in mixed decay mode. Google stepstuck hack. I recently applied the hack and the extruder motor runs much smoother.
