Dual X axis motor
September 13, 2015 05:12AM
Hey I wonder if a dual x axis motor setup would eliminate ghosting and cornering?
Like mirroring the x axis motor mount and puttting it on the right side aswell?
Blog: Capotexl
Filament Factory - How to build your own cheap filament extruder
Frankenstein Laser Engraver
Make the world a better place
Re: Dual X axis motor
September 13, 2015 04:43PM
I don't believe two motors may help.
First, a single motor is pretty enough for that task.
Possibles issues and solutions :
_ flexible belt => replace with quality fiberglass armoured belt.
_ wobble => replace your loose LM8UU by polymer or bronze bushings, and tight them for a no clearance fit.
_ not so round idler pulleys/bad belt guidance => replace idler bearings by proper GT2 pulleys mounted between 2x625RS bearings on custom Xend with flanges.
++JM
Edited 1 time(s). Last edit at 09/13/2015 04:44PM by J-Max.
