Prusa i3 z axis problem (drives into a bed) October 08, 2015 08:24AM |
Re: Prusa i3 z axis problem (drives into a bed) October 08, 2015 08:57AM |
Re: Prusa i3 z axis problem (drives into a bed) October 08, 2015 09:42AM |
Re: Prusa i3 z axis problem (drives into a bed) October 08, 2015 10:00AM |
Re: Prusa i3 z axis problem (drives into a bed) October 08, 2015 11:13AM |
Re: Prusa i3 z axis problem (drives into a bed) October 08, 2015 04:01PM |
Re: Prusa i3 z axis problem (drives into a bed) October 13, 2015 04:51AM |
Re: Prusa i3 z axis problem (drives into a bed) October 13, 2015 04:02PM |
Re: Prusa i3 z axis problem (drives into a bed) October 14, 2015 03:19PM |
Re: Prusa i3 z axis problem (drives into a bed) October 14, 2015 05:57PM |
Re: Prusa i3 z axis problem (drives into a bed) October 14, 2015 09:49PM |
imqqmi
#define Z_PROBE_OFFSET_FROM_EXTRUDER -10.88...
...Then move the Z axis down by 1mm increments until it hits the bed. Use a sheet of A4 80g paper, it should just fit under the nozzle with a bit of light friction. Read the z position, this should be used as the new Z offset. Either use the display if you own one or the gcode
M114
Re: Prusa i3 z axis problem (drives into a bed) October 15, 2015 04:46AM |
Re: Prusa i3 z axis problem (drives into a bed) October 17, 2015 06:52AM |
