Electron 3D - Sixth Generation Prusa i3 Anyone? October 08, 2015 09:43PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 09, 2015 11:47AM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 09, 2015 08:02PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 10, 2015 03:50AM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 10, 2015 09:53AM |
o_lampe
Don't you have a drill to make new holes to fit the large aluminum sheet ?
BTW, a new drill is cheaper than buying a new sheet.
-Olaf
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 10, 2015 10:20AM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 11, 2015 02:32PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 11, 2015 08:59PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 11, 2015 09:18PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 17, 2015 12:01PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 17, 2015 11:18PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 18, 2015 06:58PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 18, 2015 08:19PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 20, 2015 11:17AM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 20, 2015 04:01PM |
FirstAvenger
Ok, so I'm trying to finish this up over the weekend here and just have a couple of probably really dumb questions regarding the wiring on this........
1. All the extruder wiring is done except the nozzle wires. They are identical, no markings as to being positive or negative, they are both the same color, no stripes or other identifying marks. IS there a psoitive and negative on this or does it even matter?
2. The heat bed wiring. THe heating element itself has a white wire and a black wire, as opposed to red and black. IS the white positive and the black remains negative like the rest of the wiring?
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 20, 2015 04:22PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 20, 2015 05:06PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 23, 2015 07:24PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 26, 2015 12:02PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 26, 2015 09:31PM |
cmaet
I finaly gave up on the stock ALU hotbed... Nothing sticks to it, using hairspray or glue didn't help. Tape worked great, as long as I was printing small parts. When the parts became larger, they warped taking the tape with them (printed part was still perfectly stuck to the tape, but the tape lifted from the ALU printbed.
The reason why I resisted the change for so long is the auto tramming. The induction sensor doesn't work on the glass bed, but finaly I found a solution...
I bought a siutable size glass from a local shop (paid 1,5€), and tried printing on it - works like a charm. The largest peaces that I can barely fit to the buildplate only diagonally finished perfectly - no more warping. i used 70 degree C temp for the bed (PLA) and applied some UHU glue to the glass.
But the real discovery is the tramming / leveling sensor that works on glass: [www.pibot.com]
I just ordered it today, so can't tell how well it works yet, but have high expectations for it... Will report back after I try it out.
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 27, 2015 06:51AM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 27, 2015 11:14AM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 27, 2015 05:47PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 27, 2015 09:03PM |
rowdyjoe
Just ordered the Electron 3D from 3Dprinter online (no upgrades) and looking forward to the challenge of making it work. Thanks for the info and wisdom you folks share here. I'm sure I'll find it very useful as I am brand new to 3D printing.
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 27, 2015 09:08PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 29, 2015 06:25AM |
FirstAvenger
Based on pics I've seen online and videos, it appears that the heat bed is generally the same size as the printing bed, be it aluminum or borosilicate.
I purchased the 'large print area' upgrade when I bought this Electron, and the heat element supplied is the same width, but distinctly shorter length than the Aluminum bed supplied.
Am I going to need to purchase a new heating element to match the size of the bed?
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 29, 2015 10:24AM |
dburas
So for the upgrade to the larger bed, they just sent you a longer aluminum bed but not a larger carriage or heat pad ?? So that's what they charged $60 for ?? WOW, never again 3dprintersonlinestore.
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 29, 2015 03:26PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 29, 2015 04:55PM |
Re: Electron 3D - Sixth Generation Prusa i3 Anyone? October 29, 2015 09:10PM |
