Filament jam after every print October 12, 2015 03:51PM |
Re: Filament jam after every print October 12, 2015 06:11PM |
Re: Filament jam after every print October 13, 2015 03:09AM |
Re: Filament jam after every print October 13, 2015 09:39AM |
Re: Filament jam after every print October 14, 2015 10:15AM |
o_lampe
The filament curls between extruder gear and heatbarrier?
I've seen pictures where the heatbarrier ( the hollow M6 screw ) is not screwed all the way up to the extruder gear.
If there's a gap between gear and heatbarrier, the filament tends to curl. Then the stepper starts to click, because it can't extrude anymore.
If you can't screw the heatbarrier further up, try to add a short PTFE tube as filament guide.
-Olaf
widespreaddeadhead
Also, 210C seems a little high for PLA, what brand are you using?
Re: Filament jam after every print October 15, 2015 03:14AM |
Re: Filament jam after every print October 15, 2015 10:51AM |
Re: Filament jam after every print October 15, 2015 11:47AM |
Qdeathstar
I had this problem recently and found that it was because my cold end was getting too hot and while the heat was on for the first time it would still push through, but after it cooled and hardend it wouldn't remelt...
Re: Filament jam after every print October 15, 2015 12:16PM |
AudaciousTuddle
Qdeathstar
I had this problem once or twice too. I had to use a blow torch to fix it.
Re: Filament jam after every print October 15, 2015 01:37PM |
