Keeping thermistor in hot end
Posted by Flyer
October 15, 2015 11:42PM
So, I've got a Folgertech v3 and the thermistor is held in the hot end by a tiny (1.5mm) set screw. The thermistor has a little brass collar around it so when you insert it into its hole in the block, you can tighten the set screw to hold it in place. I can't find replacement thermistors with this little collar and I'm concerned that if I put the normal thermistor into the hole in the block and tighten the set screw it will break. How do others hold the thermistor in the block?? Thanks
Re: Keeping thermistor in hot end
October 16, 2015 08:39AM
I use these [www.ebay.co.uk]
