Hello a little heatbed/Y-Carriage issue.
October 18, 2015 10:19PM
Hello RepRap Members I finally fully assembled my Prusa i3 Kit from Josef Prusa. Only issue is the Heatbed isnt sitting in the carriage correctly(Not flat against the adjustment nut). Due to this I cant calibrate/level the print bed. This problem applies to all four corners.
Here is a picture of the setup with the heatbed and carriage.
Any of you guys/girls ever faced this problem/situation? Any Tips/help is appreciated
Edited 3 time(s). Last edit at 10/19/2015 12:06AM by Jarva.
Currently own a Original Prusa I3 Kit by Josef Prusa.
Currently Working on (Leveling Heating bed) 10/18/15
Future Plans: Get Octoprint running and maybe print another reprap.
Re: Hello a little heatbed/Y-Carriage issue.
October 18, 2015 11:01PM
It is very difficult to see but it looks like you don't have springs to support the bed installed. You should have a spring between heated bed and the carriage.
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
October 18, 2015 11:16PM
This kit never included any springs for the heatbed. I followed all instructions from here. The main issue is that the screw doesnt slide all the way down into the carraige leaving a gap of 1-5mm between the carriage and adjustment nylon nut(Orange Part).
Here is another picture hopefully could help you guys identify the issue. I think its because of the flex the pcb heatbed has causes the screw to have a slight angle instead of being straight.
Edited 1 time(s). Last edit at 10/18/2015 11:16PM by Jarva.
October 18, 2015 11:22PM
Jarva
you need some springs, for leveling.
October 18, 2015 11:27PM
Qdeathstar
Where would the spring be placed and also what spring is recommended for a M3x18 Screw?
Thank you Q and gmckee for the advice/help.
October 19, 2015 12:08AM
I think a spring from any cheap pen would do, but I doubt its strengths. Can refer to mine here [imgur.com] and just ignore those sketches, it was meant to be on other thread.
As for mine, I replaced the orange rosette to this thing here [www.thingiverse.com] so that I don't have to use 2 hand to screw it
October 19, 2015 08:44PM
sarf2k4
Ah thanks i am reading on the other forum where the offical fourm is for the product. I read that all i need to do is push it down, Ill give that one a try and see how it goes as currently atm I dont have any springs(or pens really).
October 22, 2015 08:48AM
If it is a 3-point design, you could do it without springs. Theoretically you could also do it with 4-point, but you might have a difficult time.
October 24, 2015 06:29PM
RRuser
Can you elaborate ?
So i decieded to wing it and have it semi leveled for a print. Here are the results.
One thing i noticed off the bat was that the skirt and the first layer of the main print ended up overlapping/touching.
I can conclude some problems are introduced due to unleveled build platform.
I want the communities thought on this.
Thanks
October 24, 2015 08:01PM
I would take a look at the pictorial print troubleshoot guidehere. It looks like you have a bit of axis drift and temperature issues. Make sure your belts are tight and try the print cooler and incrementally up the temprature.
Just remember not to get impatient. It takes time to get everything perfect.
October 24, 2015 09:54PM
gmckee
Ah thank you that page is really helpful.
Would you say this is alot of play on the y axis belt?
October 25, 2015 11:34PM
Springs only help when adjusting from one side. If you replace the springs with a nut, then you just do a hard-adjust instead, from both sides (hex driver on top, wrench or pliers holding the nut on the bottom).
Springs don't really do anything else, such as a shock absorber on a car would.
October 29, 2015 10:29PM
RRuser
How should I proceed? I finally got a dremel 200 ,I am currently thinking about using it to grind out the HB screw holes a bit so the screws would slide through the holes with a little bit of resistance.
November 03, 2015 11:01PM
Update: I semi fixed the heatbed issue by drilling/grinding out the mounting holes for the screws to slide through(There was flex in the HB PCB so it caused alot of friction with the screws and mounting hole.) Now the only issue I face is a little bit of x blacklash and sometimes curling of the print(ABS). Looking into printing a belt tensioner and the curling could ethier be a slight deviation on how leveled the bed is or the heatbed isnt hot enough or a slight breeze.
Any tips would be great.
PS on the bottom of the print it doesnt seem like the base layers touch each other.
November 06, 2015 06:54AM
If the bolts are not still, the bed will shift from side to side. Should not affect Z though. If your Z is off, especially too far away, your first layer won't stick and will look thin.
