Zonestar Prusa i3 Power / LCD Flickering November 02, 2015 04:18AM |
Re: Zonestar Prusa i3 Power / LCD Flickering November 02, 2015 01:15PM |
Re: Zonestar Prusa i3 Power / LCD Flickering November 03, 2015 04:06AM |
Re: Zonestar Prusa i3 Power / LCD Flickering November 04, 2015 09:40AM |
Re: Zonestar Prusa i3 Power / LCD Flickering November 06, 2015 07:05AM |
Re: Zonestar Prusa i3 Power / LCD Flickering November 06, 2015 12:11PM |
The heat sinks too small or the MOSFETs have not been (over)dimensioned properly. Replacing them with one with a lower Rdson at Ugs = 5V MOSFET, it won't get as hot and probably don't even need a heat sink. The part number printed on the MOSFET can be searched on google and you'll find the data sheet with all the relevant data. MOSFETs also prefer to be driven by pulses, so one could use pwm so that at least 10% of the time the MOSFET is turned off. I use pwm of 127 (of a max of 255, MAX_BED_POWER 127) on a 12V MK2a with 24V. The current stays under the 11A max for the polyfuse and the MOSFET doesn't overheat.Quote
langassve
I had the exact same behavior and it turned out that the heat zinks on the PCB is to small so the MOSFET's get to hot. I put a fable fan in front of them and now it works fine, I guess I'll print a holder for a small 12V fan at the PCB when I can..
Re: Zonestar Prusa i3 Power / LCD Flickering November 06, 2015 11:12PM |
Re: Zonestar Prusa i3 Power / LCD Flickering November 06, 2015 11:18PM |
Re: Zonestar Prusa i3 Power / LCD Flickering December 07, 2015 12:17AM |
Re: Zonestar Prusa i3 Power / LCD Flickering December 07, 2015 01:11AM |
Re: Zonestar Prusa i3 Power / LCD Flickering December 07, 2015 02:03AM |
Re: Zonestar Prusa i3 Power / LCD Flickering December 07, 2015 10:21PM |
Re: Zonestar Prusa i3 Power / LCD Flickering December 07, 2015 10:22PM |
Re: Zonestar Prusa i3 Power / LCD Flickering January 04, 2016 01:53AM |
Re: Zonestar Prusa i3 Power / LCD Flickering January 18, 2016 02:55PM |
