Built Wilson TS, having some issues!!! November 10, 2015 06:14AM |
Re: Built Wilson TS, having some issues!!! November 11, 2015 07:26AM |
Re: Built Wilson TS, having some issues!!! November 11, 2015 02:43PM |
Re: Built Wilson TS, having some issues!!! November 12, 2015 07:32AM |
Re: Built Wilson TS, having some issues!!! November 12, 2015 12:15PM |
Re: Built Wilson TS, having some issues!!! November 13, 2015 06:34AM |
mjrice
1) it doesn't sound like it's your voltage regulator if you can get the motors to move in one direction but not the other, that is almost always because the endstops are hooked up wrong OR your firmware settings for the end stops are wrong. In your configuration.h, you should have pullups enabled for the endstops, which leads to (2)
2) you may be experiencing just known bugs with marlin, or at least the dev version of marlin. I have patched several such issues in my forked version of marlin (github.com/mjrice/Marlin) - you may want to give that a try and see if it cleans things up (you'll just need to define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER.
Re: Built Wilson TS, having some issues!!! November 15, 2015 08:53PM |
Re: Built Wilson TS, having some issues!!! November 16, 2015 12:11AM |
Re: Built Wilson TS, having some issues!!! November 17, 2015 02:45PM |
Re: Built Wilson TS, having some issues!!! November 19, 2015 09:00PM |
Re: Built Wilson TS, having some issues!!! November 20, 2015 11:46PM |
const short temptable_8[][2] PROGMEM = {
{1*OVERSAMPLENR, 938},
{31*OVERSAMPLENR, 314},
{41*OVERSAMPLENR, 290},
{51*OVERSAMPLENR, 272},
{61*OVERSAMPLENR, 258},
{71*OVERSAMPLENR, 247},
{81*OVERSAMPLENR, 237},
{91*OVERSAMPLENR, 229},
{101*OVERSAMPLENR, 221},
{111*OVERSAMPLENR, 215},
{121*OVERSAMPLENR, 209},
{131*OVERSAMPLENR, 204},
{141*OVERSAMPLENR, 199},
{151*OVERSAMPLENR, 195},
{161*OVERSAMPLENR, 190},
{171*OVERSAMPLENR, 187},
{181*OVERSAMPLENR, 183},
{191*OVERSAMPLENR, 179},
{201*OVERSAMPLENR, 176},
{221*OVERSAMPLENR, 170},
{241*OVERSAMPLENR, 165},
{261*OVERSAMPLENR, 160},
{281*OVERSAMPLENR, 155},
{301*OVERSAMPLENR, 150},
{331*OVERSAMPLENR, 144},
{361*OVERSAMPLENR, 139},
{391*OVERSAMPLENR, 133},
{421*OVERSAMPLENR, 128},
{451*OVERSAMPLENR, 123},
{491*OVERSAMPLENR, 117},
{531*OVERSAMPLENR, 111},
{571*OVERSAMPLENR, 105},
{611*OVERSAMPLENR, 100},
{641*OVERSAMPLENR, 95},
{681*OVERSAMPLENR, 90},
{711*OVERSAMPLENR, 85},
{751*OVERSAMPLENR, 79},
{791*OVERSAMPLENR, 72},
{811*OVERSAMPLENR, 69},
{831*OVERSAMPLENR, 65},
{871*OVERSAMPLENR, 57},
{881*OVERSAMPLENR, 55},
{901*OVERSAMPLENR, 51},
{921*OVERSAMPLENR, 45},
{941*OVERSAMPLENR, 39},
{971*OVERSAMPLENR, 28},
{981*OVERSAMPLENR, 23},
{991*OVERSAMPLENR, 17},
{1001*OVERSAMPLENR, 9},
{1021*OVERSAMPLENR, -27}
Re: Built Wilson TS, having some issues!!! November 21, 2015 03:08PM |
Re: Built Wilson TS, having some issues!!! November 25, 2015 01:27AM |
Re: Built Wilson TS, having some issues!!! November 25, 2015 01:41AM |
Re: Built Wilson TS, having some issues!!! November 25, 2015 02:03AM |
SteveRoy
I only have used a wades style extruder with either a genuine j-head or a hexagon, but not a direct drive, but things should be similar if you have a direct drive.
With PLA you need to have a fan running all the time on the fins of the hot-end tube to keep the filament from expanding and cloging.
Connect it to the 12v side of the powersupply or use the 2 12v pins off the ramps.
The D9 connection on the RAMPS is for a fan to cool the piece being printed.
You could try either decreading or increading the temp to see if it helps.
To calibrate the E steps of the extruder you need to tell pronterface to extrude "x" amount of filament (usually 100mm) then measure how much it extruded.
Then using this formula adjust the steps in Marlin (using 100mm for the value extruded)- old_value being existing value in Marlin
new_value = old_value * (100 / actual_amount_extruded)
Steve
Re: Built Wilson TS, having some issues!!! November 25, 2015 02:10AM |
Re: Built Wilson TS, having some issues!!! January 17, 2016 05:11PM |
Re: Built Wilson TS, having some issues!!! January 23, 2016 03:21PM |
Re: Built Wilson TS, having some issues!!! January 23, 2016 08:09PM |
Re: Built Wilson TS, having some issues!!! January 26, 2016 05:40PM |
Re: Built Wilson TS, having some issues!!! February 03, 2016 06:20PM |
