Thinking of buying a P3Steel kit from Orballo November 14, 2015 07:43AM |
Re: Thinking of buying a P3Steel kit from Orballo November 16, 2015 08:38AM |
Re: Thinking of buying a P3Steel kit from Orballo November 16, 2015 06:47PM |
Re: Thinking of buying a P3Steel kit from Orballo November 19, 2015 05:37PM |
Re: Thinking of buying a P3Steel kit from Orballo November 20, 2015 07:01AM |
Re: Thinking of buying a P3Steel kit from Orballo November 25, 2015 08:43AM |
Re: Thinking of buying a P3Steel kit from Orballo November 25, 2015 02:39PM |
Re: Thinking of buying a P3Steel kit from Orballo November 25, 2015 05:48PM |
Re: Thinking of buying a P3Steel kit from Orballo December 02, 2015 07:21PM |
Re: Thinking of buying a P3Steel kit from Orballo December 05, 2015 09:15AM |
Re: Thinking of buying a P3Steel kit from Orballo December 08, 2015 05:22PM |
Re: Thinking of buying a P3Steel kit from Orballo December 09, 2015 09:46AM |
Re: Thinking of buying a P3Steel kit from Orballo December 09, 2015 01:49PM |
paulhurleyuk
So my printer arrived after two weeks. All parts appear there, although packaging wasn't amazing. Also, no instructions, although I've emailed Orballo and they've replied that they will send some.
Initial unboxing pics here https://flic.kr/s/aHskpxMLyc .
I'll be posting some assembly pics somewhere, and will update this thread.
Paul.
www.paulhurley.co.uk
ade2
Hi! Please keep us posted. I've also ordered this kit from Orballo, last week, and I'm waiting for it to be sent. It would be interesting to learn about your experiences with the kit.
My configuration is:
- 1.75mm
- Ramps 1.4sb
- Heatbed MK3 ALU 12V/24V
- DRV8825 drivers
Re: Thinking of buying a P3Steel kit from Orballo December 20, 2015 10:38AM |
Re: Thinking of buying a P3Steel kit from Orballo December 24, 2015 08:02AM |
Re: Thinking of buying a P3Steel kit from Orballo December 26, 2015 07:22PM |
Re: Thinking of buying a P3Steel kit from Orballo December 26, 2015 07:37PM |
dvx
What would be useful to know is how many DVR8825 driver modules are needed, I have x 4 of these. Also, should there be a fan for the extruder?
Re: Thinking of buying a P3Steel kit from Orballo December 27, 2015 05:36AM |
Re: Thinking of buying a P3Steel kit from Orballo December 27, 2015 08:10AM |
Re: Thinking of buying a P3Steel kit from Orballo December 27, 2015 09:14AM |
Re: Thinking of buying a P3Steel kit from Orballo December 28, 2015 01:27PM |
Re: Thinking of buying a P3Steel kit from Orballo December 30, 2015 06:35AM |
Re: Thinking of buying a P3Steel kit from Orballo January 01, 2016 06:39PM |
Re: Thinking of buying a P3Steel kit from Orballo January 06, 2016 01:27PM |
Re: Thinking of buying a P3Steel kit from Orballo January 06, 2016 04:05PM |
Not sure. Is the movement quiet and smooth or loud and jerky ? Is there anything on the pronterface console (like endstop triggered or anything ? Marlin includes soft endstops where after homing, it will only move each axis the distance defined, which in my config was 190mm in each axis.Quote
DVX
1/ When moving each axis, I can move 5-10cm and then the stepper motors stop, sometimes they then start again for more movement.
I can not reverse the direction back to the home position, is this normal?
Yes, thats where it goes.Quote
2/ I have yet to fit the white tubing in the extruder, is this cut to fit in to the extruder hole with the bottom end in contact with the top of the hotend and the top end just short of the hob bolt?
Cool. see my comments for 1.Quote
3/ I loaded up Pronteface and this communicates Ok with the printer, but I don't have full axis movement
In Marlin you can set the axis limits, I think I defined it as 190,190,190mmQuote
4/ How do I set up the limits to the axis movements?
Each driver has a small adjustment screw where you can set the current it provides. Too little and the motor won't move and can skip steps, too much and the driver gets really hot and can thermal shutdown until it cools a bit. Follow the guide at http://reprap.org/wiki/Pololu_stepper_driver_board to adjust the current. I do still have a small fan blowing across the RAMPS unit.Quote
5/ My DRV8225 heatsinks get very hot is this the same for yours? (it might be good to have fan blowing over them)
Follow Triffid Hunters calibration guide to calibrate the printer, then follow the sections in the calibration guide to level the bed and adjust the Z height home position, then you're good to go. If you're anything like me you'll soon be printing all kinds of calibration thing, so make the first print something cool. (I did Marvin)Quote
6/ What else do I need to do to get the printer ready for it's first print?
How much of a deviation ? My Z axis threaded rods wobble about 5mm at the very top while revolving, which AFAIK is acceptable, especially if the top of the rods is free to move (that the X axis will run on the smooth rods and the z axis threaded rods will just move to adjust).Quote
I noticed on my z axis the threaded rods do not run parallel to the vertical steel rods, the gap is wider at the top, so I might remove the Z axis stepper motors and elongate the fixing holes to bring the threaded rods mor into alignment.
Re: Thinking of buying a P3Steel kit from Orballo January 07, 2016 06:35PM |
Re: Thinking of buying a P3Steel kit from Orballo January 09, 2016 07:29PM |
Re: Thinking of buying a P3Steel kit from Orballo January 11, 2016 06:07AM |
Re: Thinking of buying a P3Steel kit from Orballo January 11, 2016 08:25AM |
dvx
My last 2 prints have produced some significant extruder and hotend clogging. After dissembling and cleaning the hot end and extruder I noted the white tubing material had melted at one end
The thermistor had melted into the hotend
Re: Thinking of buying a P3Steel kit from Orballo January 11, 2016 12:54PM |
