Re: Thinking of buying a P3Steel kit from Orballo March 02, 2016 07:49AM |
Re: Thinking of buying a P3Steel kit from Orballo March 07, 2016 10:29AM |
Re: Thinking of buying a P3Steel kit from Orballo March 11, 2016 09:12AM |
Re: Thinking of buying a P3Steel kit from Orballo March 12, 2016 08:36AM |
Re: Thinking of buying a P3Steel kit from Orballo March 12, 2016 08:38AM |
Lirux
Hi people.
Anyone got the assambly instruction to the p3stell kit? I wrote them some days ago via e-mail and chat, but didn't get a reply yet.
I found some on the www. But they are not exactly for the orballo version...
Thanks,
David
Re: Thinking of buying a P3Steel kit from Orballo April 30, 2016 05:38PM |
Re: Thinking of buying a P3Steel kit from Orballo September 25, 2016 06:38PM |
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 07:20AM |
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 09:57AM |
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 05:23PM |
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 05:43PM |
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 05:51PM |
) and various Bowden type extruders - bulldog, airtripper, the jonaskuehling version of Wade's, so many to choose from... I would prefer to source good parts straight away for this printer. Which is maybe what I should have done in the first place rather than starting off with a cheap Chinese kit, though on the other hand, I did learn and am learning lots by having to look literally everything up to get it to print. |
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 05:53PM |
biocomp
Just an FYI, even if seller DOES respond quickly, it doesn't mean everything else will go well.
As with my case, kitprinter3d.com did reply quickly at first, up until the point they started owing me money. Then they suddenly stopped being responsive.
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 06:38PM |
. The encoders are a testing project from a user (/u/Chris-Aus3D) on reddit who is currently developing them and was looking for testers for feedback and mounting options a few weeks back. Basically going to be mounting them onto the X and Y axes to make a closed loop system for increased accuracy (this was partly my reasoning to redesign my whole machines printed parts and also to practice Fusion 360). |
Re: Thinking of buying a P3Steel kit from Orballo September 26, 2016 07:33PM |
Re: Thinking of buying a P3Steel kit from Orballo September 27, 2016 04:20AM |
Re: Thinking of buying a P3Steel kit from Orballo September 27, 2016 05:46AM |
Re: Thinking of buying a P3Steel kit from Orballo September 27, 2016 06:02AM |
Re: Thinking of buying a P3Steel kit from Orballo September 27, 2016 07:29AM |
Re: Thinking of buying a P3Steel kit from Orballo September 27, 2016 07:35AM |
Re: Thinking of buying a P3Steel kit from Orballo September 27, 2016 09:45AM |
ade2
I haven't been considering dual extrusion. If I did, it would probably be only to print with a dissolvable support material.
I've seen dual titan extruder setups on thingiverse. It's probably not unreasonable at all, considering the modest weight of the extruder and smaller stepper.
Iako
With regards to the encoders, still finishing off printing my parts and sourcing some of the components. Hopefully my spool of PETG will not run out before I'm done. Will definitely update as I progress. I'm also probably going to be fixing up some of the models to take the threaded brass insets, although I think it might be better to let the user decide if they wanna use them or not and just drill out the holes if needed.
Not sure where you're located, but I've got my aluminium plates from aluminium warehouse in the UK and then had a friend forward them to me to Cyprus since they only deliver within the UK (although they will be able to hand it over to a courier if you set that up). Be sure to get plates, and preferably the EcoCast stuff since you're looking for the flattest surface that you can get and that basically is it since they mill it. You also avoid any internal material stresses since the plate is cast. Whatever you do, don't get aluminium sheets, since the rolling process will generate a lot of stress in the material and will result in warping when put through heating cycles. If you're set on using glass though, I've managed to put a couple of strips of aluminium tape onto the edges of the glass and probe against those, but the repeatability wasn't as great as I get with the aluminium plate.
No idea where you could get empty spools though...You could ask on /r/3Dprinting, as I've seen some folks with large amounts of empty spools there. I'm gonna be in a lecture tonight, so I should be able to get you a link to some of the updated files for the x-carriage at least, probably on Github, since I'm a bit lazy to republish them on thingiverse at the moment. You will need 6mm diameter x 3mm depth magnets for it though.
Re: Thinking of buying a P3Steel kit from Orballo October 04, 2016 01:40AM |
Re: Thinking of buying a P3Steel kit from Orballo October 04, 2016 01:50PM |
Re: Thinking of buying a P3Steel kit from Orballo October 04, 2016 11:48PM |
Re: Thinking of buying a P3Steel kit from Orballo October 05, 2016 07:25AM |
Re: Thinking of buying a P3Steel kit from Orballo October 05, 2016 07:56AM |
Re: Thinking of buying a P3Steel kit from Orballo October 06, 2016 01:13AM |
. My order arrived yesterday Oct 4th, ordered on Sep 24th so the turnaround time was not bad. Opened the box today and all looks well, except that I'm not certain if all printed parts are there - sent them a mail regarding that. The steel frame is solid and the black finishing is much better than any paint job I could do myself, quite happy there. Decent printed parts as well, better than the photos posted earlier in this thread of last year. The packaging was decent.
. Low post counts being somewhat of a giveaway.|
Re: Thinking of buying a P3Steel kit from Orballo October 10, 2016 07:49AM |
Re: Thinking of buying a P3Steel kit from Orballo October 11, 2016 05:47AM |
Re: Thinking of buying a P3Steel kit from Orballo November 05, 2016 10:18AM |
