Re: P802M Prusa i3 Unofficial Support Thread December 06, 2015 10:42PM |
Re: P802M Prusa i3 Unofficial Support Thread December 07, 2015 02:30AM |
Re: P802M Prusa i3 Unofficial Support Thread December 07, 2015 05:00AM |
Re: P802M Prusa i3 Unofficial Support Thread December 07, 2015 05:53AM |
Re: P802M Prusa i3 Unofficial Support Thread December 07, 2015 08:26PM |
Re: P802M Prusa i3 Unofficial Support Thread December 08, 2015 02:00AM |
Re: P802M Prusa i3 Unofficial Support Thread December 08, 2015 03:27AM |
Re: P802M Prusa i3 Unofficial Support Thread December 08, 2015 05:28AM |
Robkadett
oh i googlednow i know, my P802M is not have auto leveling (sensor.)
but for a while, i can upgrade my printer with auto leveling. I think it can be work if i make senzor wire to end stop switch. and after that i have just upgrade my firmware ?
Re: P802M Prusa i3 Unofficial Support Thread December 08, 2015 02:28PM |
Hi GWC2795Quote
gwc2795
Robkadett
I have installed Inductive sensoers on 3 of my P802M printers. The sensors are working as Z endstops. I have not been able to get the G29 command to work -- it does nothing. G28 works like a charm.
I have been following this forum discussion by do not comprehend what he is saying because he wants to have the Z axis zero on the max Z axis not the min Z axis. Maybe you can give some feed back that will help me get auto bed leveling working.
[forum.repetier.com]
Re: P802M Prusa i3 Unofficial Support Thread December 09, 2015 01:59AM |
Re: P802M Prusa i3 Unofficial Support Thread December 10, 2015 11:58AM |
Re: P802M Prusa i3 Unofficial Support Thread December 10, 2015 06:24PM |
Bobyni
Hi GWC2795Quote
gwc2795
Robkadett
Was your Melzi board marked as MELZI V3b by Zonestar?
Would it be possible to see or know how you connect your induxtive sensor?
And what type of sensor did you put?
Did you add power divider on your sensor or you just plugged directly to the three pins?
Thanks for sharing
Re: P802M Prusa i3 Unofficial Support Thread December 10, 2015 11:42PM |
gwc2795
Bobyni
Hi GWC2795Quote
gwc2795
Robkadett
Thanks for sharing
I have attached a drawing of the connect to the ZoneStar V3b board
Re: P802M Prusa i3 Unofficial Support Thread December 11, 2015 12:02AM |
Re: P802M Prusa i3 Unofficial Support Thread December 11, 2015 05:25AM |
Mine is a normally closed sensor that gives off 4.84V when the sensor is not near metal, it sinks the the Z-min pin to 0.7V through the 680 ohm resistor when it is near metal.Quote
Bobyni
and what is your output voltage between the S and ground?
I just did on the bread board and it gives me 0.694V when not triggered and when triggered with metal, 0V
Re: P802M Prusa i3 Unofficial Support Thread December 11, 2015 07:07PM |
Thanks a lot for taking the time to explain!!!Quote
gwc2795
Bobyni
Only 1 lead is attached to the Z-min as shown in the drawing.
Some sensors only supply 5V to the board logic whereas my sensor supplies 12V when not sensing metal. If your sensor supplies only 5V to the board logic you will not need the voltage divider circuit just connect the black wire to Z-min as shown in the drawing.
Re: P802M Prusa i3 Unofficial Support Thread December 11, 2015 09:00PM |
Bobyni
gwc2795
Bobyni
mine is NPN NO. when no sensing it is high and when metal it goes to 0V.
I am connecting all the connectors S-+, so the voltage divider protects the Melzi board.
I have follow the Tom's guide and changed a lot of Config.h and config-adv.h in Marlin.
and did not work.....
A member of a 3D forum from France says the MELZI can handle up to 12V that he connects he's sensor directly to the three pins WITHOUT the voltage divider....
I'm quite scared to do that... it is my only board, and don't want to blow it away!
I will try your connection, but did you change anything in your firmware?
I suppose you are using Repetier 0.91? or .92?
AGAIN really appreciate your help!!!!
Re: P802M Prusa i3 Unofficial Support Thread December 12, 2015 05:14AM |
Bobyni
gwc2795
Bobyni
Re: P802M Prusa i3 Unofficial Support Thread December 12, 2015 03:32PM |
Re: P802M Prusa i3 Unofficial Support Thread December 12, 2015 03:52PM |
Bobyni
Yeah, same way here.
Still fighting with the sensor.
Using your method I can not get the sensor to work.
Sensor is triggered but the signal is not taken and hot end would sink into the bed! :-(
Tried both endsrop_ ZMINpullup true / false same result
Inverting true/false same result
Connecting all three S-+ or S alone the sme
Did you had to change something else in config.h? Pun.h?
Really at cede of grabbing a hammer!!!
Re: P802M Prusa i3 Unofficial Support Thread December 12, 2015 03:55PM |
Re: P802M Prusa i3 Unofficial Support Thread December 13, 2015 04:22AM |
Re: P802M Prusa i3 Unofficial Support Thread December 13, 2015 10:05PM |
Re: P802M Prusa i3 Unofficial Support Thread December 20, 2015 08:39PM |
Re: P802M Prusa i3 Unofficial Support Thread December 21, 2015 06:50AM |
rtideas
Both of my z motor mounts and my y motor mount cracked. Not a fan of acrylic.
After searching what I could, I gave up and modeled my own z and y replacement mounts. Just printed the parts on another i3 I have and installed them. They fit well and are near exact replacements.
Here are the STLs if you ever need them.
[www.thingiverse.com]
Also working on a power supply cover with a standard plug socket with a switch and fuse. I don't like hard wiring a power cord directly to a power supply. But need to dial it in a bit more and print a few more samples.
Re: P802M Prusa i3 Unofficial Support Thread December 21, 2015 09:28PM |
Re: P802M Prusa i3 Unofficial Support Thread December 21, 2015 09:39PM |
gwc2795
WOW!!!
Thanks for making this available. Is it OK for me to add these to the P802M [drive.google.com] parts?
Re: P802M Prusa i3 Unofficial Support Thread December 22, 2015 05:27AM |
Re: P802M Prusa i3 Unofficial Support Thread December 23, 2015 07:36AM |
Re: P802M Prusa i3 Unofficial Support Thread December 29, 2015 07:33AM |
