Re: P802M Prusa i3 Unofficial Support Thread December 29, 2015 08:49AM |
Re: P802M Prusa i3 Unofficial Support Thread December 29, 2015 02:46PM |
Re: P802M Prusa i3 Unofficial Support Thread December 30, 2015 01:29AM |
Re: P802M Prusa i3 Unofficial Support Thread December 30, 2015 02:01AM |
Re: P802M Prusa i3 Unofficial Support Thread December 30, 2015 05:39AM |
Thanks! That would be really nice. Which part should I print to attach the sensor to my printer?Quote
bmark25116
I bought the same type 6 weeks ago from Zonestar. I had ordered the printer with autobed leveling. But the delivered the printer without that. So I had to change the firmware
and connect the sensor, which the the guys delivered with some other missing parts 3 weeks later. I was not exited about the quality of this kit...But now I have all the features working.
If you want, I will send you the right firmware with ABL for a Melzi board by mail, I think you have it too. The sensor is a simple induktive sensor that you have to connect instead the z-endstop.with a voltage divider.
I think you can buy the original sensor from Zonestar what have an built in voltage divider if you send them a mail. I have used this email adresses '[email protected]' or '[email protected]'
Kindly regards
Bernd
Re: P802M Prusa i3 Unofficial Support Thread December 30, 2015 05:40AM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 02:06AM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 07:52AM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 10:23AM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 10:25AM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 12:40PM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 12:48PM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 06:35PM |
Re: P802M Prusa i3 Unofficial Support Thread December 31, 2015 07:22PM |
Re: P802M Prusa i3 Unofficial Support Thread January 01, 2016 01:14AM |
Re: P802M Prusa i3 Unofficial Support Thread January 01, 2016 01:16AM |
gwc2795
Bonyni can I post this link on the google drive for the P802M?
Re: P802M Prusa i3 Unofficial Support Thread January 01, 2016 01:34AM |
Re: P802M Prusa i3 Unofficial Support Thread January 01, 2016 08:43AM |
Re: P802M Prusa i3 Unofficial Support Thread January 02, 2016 09:27AM |
Re: P802M Prusa i3 Unofficial Support Thread January 02, 2016 05:05PM |
Hi,Quote
Robkadett
My idler mount (x-axis pulley mount) is wrong, i think.
Re: P802M Prusa i3 Unofficial Support Thread January 02, 2016 11:35PM |
Re: P802M Prusa i3 Unofficial Support Thread January 03, 2016 03:59PM |
Re: P802M Prusa i3 Unofficial Support Thread January 04, 2016 05:40AM |
Re: P802M Prusa i3 Unofficial Support Thread January 04, 2016 07:42AM |
javier.rodriguez
The problem could is the spring of the extruder you must push the lever form the extruder and insert the filament. Then use the menu to heat extruder and to "feed", If you cant push the lever, you must to disarm the spring of the extruder, i had the same problem, My problem now is that when i Print I quit the screw from then spring the printed figure is "very light" and with the srew at then middle of the print then filament stop.
Re: P802M Prusa i3 Unofficial Support Thread January 04, 2016 10:18AM |
Re: P802M Prusa i3 Unofficial Support Thread January 04, 2016 10:29AM |
Re: P802M Prusa i3 Unofficial Support Thread January 04, 2016 04:45PM |
Re: P802M Prusa i3 Unofficial Support Thread January 04, 2016 05:29PM |
Re: P802M Prusa i3 Unofficial Support Thread January 04, 2016 07:28PM |
You have to get the first layer perfect. Without the first layer right, nothing else matters.Quote
glimpse79
I really have trouble to print something with my P802M; the filament do not attach well so just at the second pass a part of the printed PLA goes away attacched to the nozzle.. any suggestions?
Re: P802M Prusa i3 Unofficial Support Thread January 05, 2016 12:23AM |
