Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 03:55AM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 03:57AM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 04:06AM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 04:10AM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 04:41AM |
ErikL
I'm also thinking about adding auto bed leveling to my P802M printer but I'm wondering if this is the right sensor ? -> [www.ebay.co.uk]
Can anyone please confirm? I'm ordering different parts from the same seller so I could add this sensor and I won't need to pay additional shipping costs..
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 05:21AM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 05:15PM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 06:12PM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 06:19PM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 07:15PM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 12:40AM |
madias
Hello,
I'm also a owner of this printer (sold as "Hesine M505" the black acrylic one - firmware is the same:FIRMWARE_NAME:Repetier_V1.4 [zonestar3d.en.alibaba.com] ).
First some quick fixes of mine (if not already written in this thread):
1) My PSU is rated 15A (on the black hesine). This is much to low, turn the skrew on the PSU to max 13.5V for getting some degrees more on the heatbed and stability reasons. (Meanwhile I exchanged the PSU)
2) Isolate the heatbed on the backside (I have done it with a 5mm styrofoam plate wicked into aluminum foil and double sided heat proof tape)
3) Use thermal compounds between the heatbed and the alu plate. With this 3 fixes I got about 100 degrees on the heatbed without expensive modifications, (nearly) enough for printing ABS!
4) Place the whole printer on a rubber mat (as sold for loudspeaker) Gives me 2/3 less noise and less vibrations.
5) The Melzi board comes with a FAKE FTDI chip. So be careful which drivers (especially on windows) you install! Google for fixes and instructions ("FTDI brick")
6) My melzi board comes without bootloader (so you need an UNO or USBISP for updating the firmware)
And now some questions of mine:
I'll upgrade the printer for several reasons to RAMPS 1.4 and I wanna safe some entries from my original firmware, but I got really strange results out of the EPPROM settings:
EPR:3 3 100.0000 X-axis steps per mm
EPR:3 7 100.0000 Y-axis steps per mm
EPR:3 11 1600.0000 Z-axis steps per mm
These are all non standard values with our common components (M8 rods, pulleys, ....) according to [reprap.org] !
For example: X and Y should be around 80 and the Z-axis should be around 2560.
I'm not at home and I 've not done a big research (measuring all pulleys, belts-ptich,...)
So, can someone read out with repetier host the EEPROM settings and posting the results for those 3 values? Big thank you for this!
edit:
got some of the answers myself (after researching at the sellers aliexpress page)
Z Axis: With the calculator [prusaprinters.org] i got:
Motor step: 200, Driver: 16 steps, Leadscrew pitch (2mm - got this values from the sellers page), = 1600. But I can't believe it's not a metric M8 rod
for X and Y axis there must be "16" pulley tooth counts, I have to check this at home, so I got "100" according to spare parts from the seller he has the "16" teeth variants as standard product.
So the interesting question is - assuming there is only "one" master design for all those printers (afibot, hesine, P802, M505.....) and one master firmware, if all those printers are using (and shipping!) those 2mm rods AND the 16 teeth pulleys? If not, the buyer will have lots of troubles...
regards
Matthias
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 02:26AM |
madias
The flickering is caused by a bad 5v converter onboard as I can remember. People fixed it with exchange the voltage converter or powering the melzi via additional usb 5v.
I have the lcd flicker problem (all of us have it). But I fixed it another way:
In the past: setting voltage output on PSU to 13.5
now: Using new 25A PSU (also set to about 13V for better heatbed heating)
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 02:29AM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 02:48AM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 05:06AM |
ErikL
I haven't touched my printer' firmware yet but I'm planning on implementing auto bed leveling, so I will have to flash the firmware with the latest repetier firmware 0.92.x.
Has anyone already done that and can point me to soms relevant information and/or tips?
I guess I can, somehow, read the current configuration for the current firmware and use that configuration for compiling the newer firmware ?
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 08:59AM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 10:06AM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 12:31PM |
madias
Good news for printing flexible filaments
The simplest idea was really the best, just an additional guide for the filament prevents loops around the filament gear
Tested with 30m/s working good! More speed give bad results with "soft PLA" even with 230 degrees. But 30ms/s more than the recommended speed.
I have attached a 123D design file and also a STL file for that part.
For myself I used PETG for higher temperature resistance, feel free to experiment.
You also must drill the filament hole a bit (M3-M4, so 3-4mm)
regards Matthias
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 12:44PM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 12:46PM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 01:34PM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 02:18PM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 02:35PM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 02:51PM |
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 03:32PM |
Use Arduino 1.0.5-r2 to compile it.Quote
dsol
trying to burn 0.92 firmware and get this.. what to do ???
thanks !
got this printer...
[www.aliexpress.com]
Re: P802M Prusa i3 Unofficial Support Thread January 22, 2016 10:55PM |
madias
Zonestar/Hesine (what ever name they use now/past/future, they are all the SAME) is a really annoying company. The totally hesitated to give away the source code of their firmware in the past and this is strictly against open source policy. So copy the ideas from others (what is ok, if open source like our printer) and then they keep secret their minor changes (and errors).
But one reason why to buy a prusa i3 model was for me, to have all information so we have no problems in the future. Funny fact was, that I took even the building instructions from another company (I think afibot or something, the printer looks very similar).
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 01:13AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 03:52AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 04:31AM |
