Re: P802M Prusa i3 Unofficial Support Thread October 15, 2016 11:21AM |
. It's ok though I wasn't using the direct SD card printing anyway.
Re: P802M Prusa i3 Unofficial Support Thread October 16, 2016 12:44AM |
Re: P802M Prusa i3 Unofficial Support Thread October 16, 2016 05:58PM |
Re: P802M Prusa i3 Unofficial Support Thread October 17, 2016 01:03PM |
Re: P802M Prusa i3 Unofficial Support Thread October 17, 2016 06:59PM |
bitslapper
I got the sensor working.
Now i just need to get it as close to the head z position as possible as my prints were coming out crappy and not sticking since the head was way too high.
I was messing with the position last night and got way too over zealous as the head smashed into the bed and proceeded to drag in the x dir -_- ... luckily i had blue painters tape on so it softened the blow a little. I really need a power switch as unplugging from the wall takes way too long.
Hopefully tonight ill get it running properlyj
Edit: Mine came with an aluminum bed but I haven't tried printing in abs yet, only in pla. The heated bed works nice to help the pla stick at about 60c . I haven't seen warping but i haven't been printing for too long and have onpy printed small test items so far...
Re: P802M Prusa i3 Unofficial Support Thread October 18, 2016 04:47AM |
Re: P802M Prusa i3 Unofficial Support Thread October 18, 2016 01:46PM |
Bobyni
bitslapper
Great! Hehehe that happened to me too, it went deep and scored the blue tape!
Once rou have the good distance of Z end, adjust the z offset from the printer key directly... By default it is set to 0.5.
Cheers!
Them, mine was the first batch of e printer that were sold on Aliexpress! Or we are not talking the same thing!
I am saying the H form support plate that on top, we mount the heated bed and then the aluminum plate...
I need to upgrade my SUPPORT from acrylic to metal
Re: P802M Prusa i3 Unofficial Support Thread October 18, 2016 03:35PM |
Re: P802M Prusa i3 Unofficial Support Thread October 19, 2016 09:48AM |
Bobyni
Bitslapper, definitely you would need to adjust the Z off set!!! You are away from the bed and that's way there isn't enough "pressure" from the nozzle to "compress" the extruded plastic.
Eg.02mm resolution, nozzle 0.4mm then the nozzle should start not at Z=o rather Z=0.2 .
But when using the Sensor, the sensor is higher ( further) than the nozzle you would need to let the board to know that info.
So it would start at z=0.2
Make sense?
Re: P802M Prusa i3 Unofficial Support Thread October 19, 2016 10:55AM |
Re: P802M Prusa i3 Unofficial Support Thread October 19, 2016 07:38PM |
bitslapper
Bobyni
Make sense?
Yea that makes sense. OK I'll try that.
So I need to adjust the Z Offset for the nozzle resolution correct?
Also, is there a base Z position that needs to be adjusted for the distance between the nozzle and the sensor?
Thank you for the help!
Edit:
OK I think I might understand what you were talking about a little better now....
So, if I understand this correctly, the variable Z_PROBE_OFFSET_FROM_EXTRUDER in the firmware is the mm offset from the extruder.
Then there is a separate value in the printer settings you manually enter in slicing software later for the resolution of the nozzle?
Re: P802M Prusa i3 Unofficial Support Thread October 20, 2016 09:37AM |
Re: P802M Prusa i3 Unofficial Support Thread October 20, 2016 09:40AM |
Re: P802M Prusa i3 Unofficial Support Thread October 20, 2016 11:18PM |
Re: P802M Prusa i3 Unofficial Support Thread October 21, 2016 09:09AM |
Bobyni
Hum mm
I have never ever got that!
Try to adjust the pressure from the screw that pressure the gear.
It should be strong but not that strong....... The sweet spot
And good luck!
Re: P802M Prusa i3 Unofficial Support Thread October 21, 2016 08:23PM |
Re: P802M Prusa i3 Unofficial Support Thread October 22, 2016 02:53PM |
Re: P802M Prusa i3 Unofficial Support Thread October 22, 2016 03:06PM |
I think you would need to go to ultimaker to ask, unless you are using the wrong firmware.Quote
ScottyBoyo
im not sure if this belongs here but my machine is a Pursa I3 Pro so ima put it here
I added a bed leveling sensor to my Printer and enabled all the Auto bed leveling code but the safe homing feature doesnt seem to work when homing the machine it just goes to the end of the bed and then goes down and with no end stop it just hits the bed and keeps trying to go down the safe homing code tells it to go to the center of the bed before homing the z axis but the machine doesnt do it im using marlin software and will include the current file uploaded to the printer any help would be appreciated as i have yet to get a successful print from this machine.
Re: P802M Prusa i3 Unofficial Support Thread October 24, 2016 12:38PM |
Re: P802M Prusa i3 Unofficial Support Thread October 26, 2016 03:59AM |
Re: P802M Prusa i3 Unofficial Support Thread October 26, 2016 07:20PM |
siblues
Hello, I just wanted to ask a few questions before I receive my P802NR in the mail on Friday.I am extremely new to this and I am just trying to read and gather as much information as possible.I have a few questions regarding a lot of the available slicers.The manufacturer of my machine Zonestar is recommending Kisslicer and I have downloaded it and cura and repetier just to get a feel for each one.I am leaning towards Cura and or Repetier.The kisslicer seems a bit basic out of the box and looks like you need a better grasp of how all this works to set it up properly.I just wanted to ask what you would recommend as a slicer for someone like me.I am wondering what printed parts I can make on the printer to fix some of it's known issues like supports , motor mounts , cooling fan mounts or the like?Thanks for the help
Re: P802M Prusa i3 Unofficial Support Thread October 26, 2016 10:47PM |
Re: P802M Prusa i3 Unofficial Support Thread October 27, 2016 06:33AM |
siblues
Thanks a lot.I was already leaning in that direction and the only reason I even mentioned Kisslicer is because the manufacturer recommended it and I tend to try to keep things as simple as possible in the beginning.What would be some of the most common things to worry about with this printer to start off with.Does it have any design flaws that can cause a first timer like me issues?I have stocked up on wear and tear parts ahead of time and I was recommended using a .3mm nozzle for cleaner prints.I am not too worried about extending the print times right now since I am just doing this for fun and personal use.The printer is in a location that is a little dusty so I am thinking about using some corugated plastic to make a simple and most likely ugly enclosure but the more you read online the more you want to do because of all the horror stories so I figured I would ask in here for what I really should be worried about.
Re: P802M Prusa i3 Unofficial Support Thread October 27, 2016 07:43AM |
Re: P802M Prusa i3 Unofficial Support Thread October 29, 2016 02:44AM |
Re: P802M Prusa i3 Unofficial Support Thread October 31, 2016 01:29PM |
Re: P802M Prusa i3 Unofficial Support Thread October 31, 2016 09:01PM |
Re: P802M Prusa i3 Unofficial Support Thread November 01, 2016 03:48PM |
Re: P802M Prusa i3 Unofficial Support Thread November 01, 2016 05:37PM |
siblues
Well with a lot of help from a good friend it's up and running.I just wanted to ask about leveling the bed.I have seen a few videos on everyones own version of the right way to do it.I just have one question regarding the sensor on the extruder.The sensor comes in contact with the bed before the actual nozzle.I can adjust the sensor up and down but it will take a little dissasembly to get to one of the screws.I just want to make sure the sensor is what needs to be adjusted and not the actual nozzle?
Re: P802M Prusa i3 Unofficial Support Thread November 02, 2016 10:40AM |
