P802M Prusa i3 Unofficial Support Thread
November 21, 2015 10:23AM
I hope we can pool our questions and answers about the Zonestar P802M 3D printer.
Re: P802M Prusa i3 Unofficial Support Thread
November 21, 2015 10:50AM
The P802M came with a 5 button LCD screen. I have not been able to identify it.
open | download - IMG_0105 small.JPG (317.9 KB)
open | download - IMG_0106 small.JPG (382.3 KB)
November 21, 2015 12:15PM
I have added the P802M Firmware, P802M Printed Parts and P802M Instructions on a Google Drive.
Hope they help.
[drive.google.com]
Edited 1 time(s). Last edit at 11/21/2015 01:47PM by gwc2795.
November 22, 2015 05:04AM
That's one of the standard reprap screens.
November 22, 2015 05:32AM
RRuser
Thanks for the reply RRuser. I did not specify that I need to know what the #DEFINE would be in marlin. The P802M uses Repetier v0.91 and the Repetier configurator. The v0.91 configurator does not run on IE, Chrome or Opera on my computer so I need to convert to marlin to add a Inductive sensor for bed leveling.
It is strange about the v0.91 configuration tool because the first time I used it it ran OK, but now it will not run even though I have cleared cache and taken other steps to use it. The configuration tool will come up but will not allow me to save the configuration files, the download screen is blank.
Thanks
November 22, 2015 06:09AM
Thanks fpr sharing. I have to replace the melzi board what was delivered with the kit, because it won`t work. So I bougt a Raps 1.4 and would like to
upload the firware with the correct settings, because I am relly new in this business. Unfortunately I couldn`t download the ZIP file from the google. drive.Have I to registere there ?
Kindly regards
Bernd
November 22, 2015 06:38AM
Solved, I have got the download working. Thanks again. I will try to upload this to my new Ramps board...
Bernd
November 22, 2015 07:11AM
bmark25116
Bernd
Good luck. let us know
November 22, 2015 07:30AM
I will do my best, just now I have chaged the motherboards settings with the repetier configuration tool.
Hoping that works...
Bernd
November 22, 2015 11:47AM
bmark25116
Bernd
Wish I could help you more but the V0.91 Repetier Configuration tool will not download any configuration I make. V0.92 will not compile so I am having to convert to Marlin.
November 22, 2015 02:34PM
I changed the settings with 0.92, 0.91 doesn`t work with me...
Butit is not everything working...
Bernd
November 22, 2015 05:49PM
bmark25116
Bernd
I can't get either one of them to work either.
November 23, 2015 01:41AM
0.91 doesn´t support using the 12864 full graphic display I think, because there are displays shown in USER INTERFACE ?
But there is a lot of other trouble with repetier. Is it better to use Marlin and can I use the Repetierhost with it ?
Bernd
November 23, 2015 05:04AM
bmark25116
Bernd
Yes you can use Repetier with Marlin.
What is a 12864 display?
November 23, 2015 05:51AM
Tht is fine , makes it easier to me.
The 12864 is displa , look hier:
[www.google.de]
Bernd
November 24, 2015 04:39AM
Hello,
thx for this thread
your google drive is usefull smiling smiley
I have bought a PL-05N captor to activate autolevelling. Do you have STL to mount It ?
tuto : [electronicgeektips.wordpress.com]
Edited 2 time(s). Last edit at 11/24/2015 04:44AM by Goldendark.
November 24, 2015 05:45AM
Goldendark
Hello,
thx for this thread
I put the P802M Sensor Mount in the [drive.google.com]
This sensor holder is for the SN04 series inductive sensors, but should fit others.
Gerry
Edited 1 time(s). Last edit at 11/24/2015 05:52AM by gwc2795.
November 24, 2015 06:39PM
Has anyone converted the P802M to run on Marlin?
November 28, 2015 05:39AM
An adjustable Inductive sensor holder has been uploaded to the google drive. It is much easier to adjust the distance between the bed and the sensor. Print 1 each adj top and 1 each adj bottom file.
Items needed:
1 each M3x50MM screw or equiv in SAE
1 each M6x40MM compression spring or equiv in SAE
[drive.google.com]
Edited 1 time(s). Last edit at 11/28/2015 05:51AM by gwc2795.
November 29, 2015 04:47PM
still no identification of the lcd?
December 01, 2015 01:49PM
I have identified the LCD supplied with the P802M.
It is PiBot Display/Controller extension with 20x4 character display
In Repetier Firmware use #define FEATURE_CONTROLLER 8
December 03, 2015 02:25AM
hiho,
iam just finished to asseble my pursa i3. works all fine at the beginning, but then nothing goes anymore. The LCD just light a bit up and when i turn off the power for a short sec i see version fimreware and so on screen. when i connect to repetier host it always says "brown out reset initialising".
Just the question, am i right that brown out means that something is wrong with the power supply?
December 03, 2015 05:16AM
Walles
hiho,
Measure the voltage on the output of the power supply. Mine is 12.12V and I do not have a problem. There is an adjustment screw on the bottom right of the power supply. I should give up to 2V additional output. Also make sure the wires from the power supply are tight especially since it is happening after the printer has started operating.
Will it heat the extruder without heating the bed?
Will it heat the bed without heating the extruder?
Also make sure you slid the input voltage selector switch to 110V, it comes set for 220V from the factory, this will cause chronic low voltage.
Edited 2 time(s). Last edit at 12/03/2015 05:22AM by gwc2795.
December 03, 2015 07:57AM
i tested it without extruder and heatbed, same problem. i tightened all wires and tried to adjust the power but nothing happens.
now i need to buy me a new voltmeter, cant find my, to check the output from the power supply.
December 03, 2015 09:51AM
Hi members!
Im happy to find this forum, i have too this printer.
under assembling. (in 2nd day i have it smiling smiley )
but i have a problem now, in first steps.
My idler mount (x-axis pulley mount) is wrong, i think.
i think the bearing is not good position, it is not paralell and its not front of each other (cant meet the holes/isnt opposite = rotated )
if i assemble it to the motor and slider rod to the hole.
When they in right place (in hole and in motor) they are thight and can not rotate/move all of them.
how can i solve it? becouse if i disassemble the bears i cant assemble it again never.
sorry my bad english.
erro like this:
December 03, 2015 11:14AM
ok, got a new voltmeter and checked the outputs on the power supply. all have 4.12V thumbs down
December 04, 2015 10:41AM
Walles
Is the switch on the power supply set to 110V it comes set to 220V
December 04, 2015 11:52AM
it work at beginning all fine, and 220v is correct for me smiling smiley
December 04, 2015 12:46PM
Walles
Adjust the voltage higher on the power supply output
Edited 1 time(s). Last edit at 12/04/2015 12:47PM by gwc2795.
December 06, 2015 02:54AM
do not wory mine scrools are 1 cm to reach the hool i left it as it is and it is working fine it is slightly in not parallel becose due to printed part
