Plans/Printed Parts for steel rod frame?
Posted by muntahunta
December 17, 2015 01:45PM
Are there any plans and printed parts to make a steel rod frame for a prusa I3?
I don't have access to anyone with a cnc to make a frame and the prices on ebay are huge, I do however have access to very cheap smooth and threaded rods (M8/M10)
I have seen pictures of these before but I can't seem to find any plans or parts.
Re: Plans/Printed Parts for steel rod frame?
December 17, 2015 02:46PM
How about Prusa i2/Mendel? >> https://github.com/josefprusa/PrusaMendel
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
December 17, 2015 03:03PM
Ah, interesting.
I've only ever looked at I3's as with them being a newer version, I assumed it was better.
Is there much difference in print quality and reliability between the two?
i'm running an I3 atm, but I want to build a backup.
December 18, 2015 12:22PM
I'm also using an i3. I own a FolgerTech Prusa i3 with a 6mm plexi frame, which can easily lose the perpendicular relationship between the Y and Z axes. to illustrate this, just grab the top of your frame and note how easily it moves backward and forward without the base leaving the table... The i2 is MUCH more reliable in this regard, but isn't as light due to the extensive use of threaded rod. Otherwise, it is very similar to the i3, in terms of performance. Take a look at my printer in the links below!
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
