Building printer from scratch - i3 Berlin/Rework/?
Posted by ziga911
December 27, 2015 09:29PM
Hi good people of internet,
after a tons of research i've decided to build my own 3D printer. Since I have access to water jet, a laser cutter and CNC, a good stiff frame should not be a problem. I would like to build a printer with quality parts and learn something, so that's why I'm not interested in cheap China kits, but to spend a 1000-1500€ is a little too much for me right now.
I was looking into a i3 Berlin. Really like the design, dual extruder... But, BOM is incomplete, not all printable parts are in there, some parts are undefined... Is it worth or should I make a Prusa i3 Rework? If somebody built a Berlin from zero, not from a kit, please let's get in touch.
Or maybe any idea about a closed case model? (benefits of heating, noise reduction etc.)
What do you suggest for electronics? Rumba, ramps, melzi?
Thank you.
Re: Building printer from scratch - i3 Berlin/Rework/?
January 08, 2016 07:22AM
Closed chamber won't affect much on your prints though (correct me on this one) but will give a boost on heatbed heat up process
Electronics probably ramps or rambo, I never used rambo, I am using ramps 1.4 now, only issues is arduino didn't have much power from the psu and I need to hook external 5v supply through the usb port
