Re: Geeetech-Aluminum-Prusa-I3 January 29, 2016 01:07AM |
MKSA
How can you make sure these sensors give you the required repeatability ? You need better than 0.1mm. These sensors are designed and used for a totally different purpose.
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 February 01, 2016 05:06AM |
bernbout
MKSA
I already mentioned testing in my previous post:
"LJC18A3-B-Z / BX I will get one and do some testing on an Arduino board " That is how I will know.
As for these sensors, many people have been using them for just such a purpose for many years and have reported success.
If I wanted to be extra sure, I'd spend $2000 to $5000 and buy one of the more expensive printers. Instead I have chosen to buy this printer, build it and enhance it. My aim is not to just print plastic things but to learn and develop. As anyone who has bought any such DIY printer, the support and warranty is almost NIL. YOU ARE ON YOUR OWN.
No guarantees.
Currently I am using a piece of paper and if I can get any more accurate than that, consistently and automatically then that is the way I go. As it is current the bed leveling system is inaccurate, tedious and one I want to eliminate.
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 February 03, 2016 08:50AM |
Re: Geeetech-Aluminum-Prusa-I3 February 11, 2016 12:43AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 February 12, 2016 11:09AM |
lexering1988
News?
). I will reinforce the vertical plate latter.|
Re: Geeetech-Aluminum-Prusa-I3 February 12, 2016 11:51PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 February 13, 2016 10:44AM |
Re: Geeetech-Aluminum-Prusa-I3 February 14, 2016 02:59PM |
Re: Geeetech-Aluminum-Prusa-I3 February 14, 2016 04:31PM |
Re: Geeetech-Aluminum-Prusa-I3 February 14, 2016 11:13PM |
AllgoodEnergy
I have just finished assembling my Geeetech all aluminum Pursa I3 yesterday and have not been able to print anything successfuly yet the extruder motor slips and coggs with a clunk clunk clunk when printing.
By the way some have had probles with the power supply I think what is happing because the supply is sent with the 110/220 Selection switch set to the 220 VAC setting. The supply kind of works on 110VAC with the supply Voltage Switch set to 220VAC but doesn't output enough current and drops to 8 Volts when under load. When set properly set it works fine regulates at 12VDC at full Load.
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 February 15, 2016 03:28AM |
Re: Geeetech-Aluminum-Prusa-I3 February 15, 2016 06:13AM |
MKSA
Had a lot a fun watching Geetech videos, they managed to assemble it without caliper, ruler, square, gauges.
At least, it's metal, a "plastic" prusa would be junk, a dead end.
Re: Geeetech-Aluminum-Prusa-I3 February 16, 2016 10:55PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 February 17, 2016 01:07PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 February 24, 2016 12:21PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 04, 2016 01:28PM |
Re: Geeetech-Aluminum-Prusa-I3 March 06, 2016 02:47PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 06, 2016 10:39PM |
but it is still OK as the Z load, the X carriage weight, is one way and slow. For other use, a proper anti backlash nut must be devised. You get what you pay for.|
Re: Geeetech-Aluminum-Prusa-I3 March 07, 2016 10:51AM |
Re: Geeetech-Aluminum-Prusa-I3 March 07, 2016 11:04AM |
Re: Geeetech-Aluminum-Prusa-I3 March 07, 2016 11:22AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 08, 2016 02:49AM |
to repace the one of the Y axis. We will see if true. If OK, I may replace all the others too.|
Re: Geeetech-Aluminum-Prusa-I3 March 09, 2016 12:51PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 09, 2016 02:23PM |
bigfilsing
think you might need to take a long look at the physical properties of 6mm acrylic v alu Often the compression/tensile properties are better than alu, added to which ...thermal expansion . Just a thought when you come to strap your PSU to the frame :-)
I came across your thread when looking for more peoples opinion about ABL . One misconception that seems to be floating around is that ABL can compensate for a concave or convex bed . ABL simply measures the bed at specific points and forms a plane from the coordinates which it considers as being the bed. Only needs 3 points to determine this plane. any more test points simply average out the readings.
Im currently running a capacitative sensor and having spent a lot of time adjusting its sensitivity ( which many dont bother with) it produces very reliable results on a glass bed. Of course i also made a point of setting the bed up mechanically properly first.
As for the 8 mm lead screw as apposed to the Prusa i3 standard M5 i think its operates more smoothly. Its also theoretically faster as the steppers have to produce less motion to achieve the same Z height increase. The lead screw nut is also longer which reduces any potential backlash. I did try a temporary backlash system on them but didn't see any improvements at all in print quality so left them out.
Heres my X ends to suit the lead screw 8mm lead screw x ends
and made some adapters for the M5 die hards M5 anti back lash adapters
One thing i would definitely recommend you putting on your list of upgrades are the TMC silent stepper drivers for the x & Y axis . Without doubt the best bang for buck upgrade i have ever done to my printers.
good luck
Re: Geeetech-Aluminum-Prusa-I3 March 09, 2016 10:34PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 10, 2016 03:20AM |
bigfilsing
Spliced a GT2 belt !!! I bet that was fun . Im not sure there are any advantages to a single Z stepper other than machine weight and power consumption The original prusa's had a single stepper/ belt drive but over the years the dual stepper configuration has been adopted. I kind of get where you are coming from in modifying yours to a single but have to admit ive never had an issue with a dual set up. Of course having the same type/ brand of steppers and a good stepper driver is needed to maintain reliable sync'd operation. Wiring them in series isnt a bad idea either
I think you need to view acrylic in the broader sense of thermo plastics then think of how much it is used in planes and cars. It isnt perfect in the application of our 3D printers ( but then again what is) but it brings an affordable, repeatable mass production accuracy to printer frames that allows non technical peoples to assemble a 3D printer that fits their budget.
The accuracy of Z sensors is more than adequate as it only effects the first layer of each print and as long as we get reasonable adhesion on the first layer were happy. It would be a different story if it was needed throughout the print process. Heated beds also don't help the repeat-ability as they never quite heat up the same every time hence non ABL set up needs to be done when everything is up to temp. Quite a few slicers allow for first layer compensation ( flow/height/width/extrusion) as well which can be useful.
The need for anti backlash isn't only determined by the thread-type/ pitch of the lead screw. The jerk & acceleration settings of the stepper(s) makes a huge difference and this is one area where i think you may come back from your intended mod to a single stepper. A Z axis driven by the belt will never react the same as the one driven directly and considering the Z movement ( jerk>acceleration>motion travel>deceleration>stop)for each print layer takes place in a matter of milliseconds dual steppers is the preferred method.
) are available for about the same price.
Re: Geeetech-Aluminum-Prusa-I3 March 10, 2016 04:24AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 10, 2016 07:40AM |
bigfilsing
i think you will be surprised at the quality and accuracy of printed parts if you are patient and spend some time on set up.
I've just come from a meeting with Igus where i have purchased some of their linear bush bearings. Hopefully they will be quieter than the standard LMU8's
they also have a whole range of supplies for 3D printers and what looks like some great filament. Looks like a good contender for a 3D printed anti back lash system.
how do you manage to see a couple of steps ??? 200 steps per rev X 16 micro steps = 3200 steps . If the differences are visible to the human eye then its more than " a couple of steps" and you should look at your system closely.
Torque is determined by both voltage and current. It is perfectly OK to have the z steppers wired in parallel tens of thousands of people have with no issues.
If i get a batch of steppers i always measure the Ohmns resistance of the coils and match up the motors closest to each other just in an attempt to "balance" things. I also make a point of making both Z stepper motors wiring looms the same length. Again trying to balance things out. Does it make a difference ?? Good question! But it certainly does no harm and my Prusa Air 2 hasn't missed a beat in over 3 years.
I would strongly recommend you consider going back to a dual Z motor set up. Regardless of what i think/say, everybody has gone down this route , even the ultra cheap Asian manufacturers who are always looking to simply machines to cut cost and give them the edge in the market. There must be a reason for this !!!
Good luck
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 12, 2016 04:57AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 14, 2016 02:04PM |
, once done, OK for 150 000 km.
