Is it normal for the lines to bunch up when using slicer
Posted by igel
January 07, 2016 10:58PM
I'm printing with 95% infil. I find that the printer prints a line then comes back and prints another one , then these two are touching when it goes to print the next parallel line to those two it is not touching. It seems that there is only a space between every other line.
I'm using a Folgertech prusa i3 and repetier host. I'm trying to do a fine tune of the esteps. If you look and zoom into the picture you can see it. Anyone else have this?
Re: Is it normal for the lines to bunch up when using slicer
January 08, 2016 06:32AM
Did you stop the print midway for the picture above? 95% isn't like top/bottom solid infills though unless you're using 100%
January 08, 2016 11:18AM
I did stop that print. Theres only a space between every second parallel line of infil that is printed. There should be a space between every line or no space at all I don't know why its doing this. Any thoughts?
Edited 1 time(s). Last edit at 01/08/2016 11:18AM by igel.
January 13, 2016 07:22AM
Is probably slack in the belts or frame.
