You may be suffering friction in your bowden tube resulting in reduction in extruded filament. Does your extruder click or strip the filament with the bowden tube attached? Ideally you want the idler tensioned to click rather than being tight enough to grind the filament.
Check your filament diameter in multiple places to ensure it is not oversize and from multiple directions to find out if it is oval.
You could set your esteps higher or ditch the bowden extruder I've found them to be very unsatisfactory.
