Firmware EEPROM Configuration menu item grayed out! January 14, 2016 09:00AM |
Re: Firmware EEPROM Configuration menu item grayed out! January 15, 2016 12:14AM |
Re: Firmware EEPROM Configuration menu item grayed out! January 15, 2016 02:50AM |
Re: Firmware EEPROM Configuration menu item grayed out! January 16, 2016 04:53PM |
Roger123D
The Eprom config will be unavailable if the printer is not connected to the computer via usb cable and connected in the program you are using as in ready to print then is should be available
Re: Firmware EEPROM Configuration menu item grayed out! January 16, 2016 05:04PM |
o_lampe
I'm not a Linux guy, but you are saying, you can't select the configuration.h tab in arduino IDE, right?
Some of the parameters are adjustable with pronterface, like "M92 Zxxx.xx" for Z-steps/mm.
If sunhokey has disabled EEprom support, you have to write the M92.... line in your slicer startcode.
-Olaf
Re: Firmware EEPROM Configuration menu item grayed out! January 17, 2016 03:10AM |
Re: Firmware EEPROM Configuration menu item grayed out! January 23, 2016 08:34PM |
