Two stepper z-axis January 14, 2016 05:27PM |
Re: Two stepper z-axis January 14, 2016 10:58PM |
Re: Two stepper z-axis January 15, 2016 04:01PM |
Re: Two stepper z-axis January 15, 2016 06:57PM |
Anonymous User
Re: Two stepper z-axis January 16, 2016 10:37AM |
UniTrader
i doubt it is technically possible for them since this would also mean they could "miss a step" if used alone which would possibly mess up the whole print, no matter which of the motors it is.
i was more afraid that the connection between the motor and the threaded rod may slip, but not anymore because i observed them a long time and rhey stayed always in snync
(to make this easier for me i attached a cable tie to each threaded rod which i didnt cut entirely at a position where they wouldnt disturb the Print - bothy stayed always in sync so far)
Re: Two stepper z-axis January 16, 2016 01:54PM |
Anonymous User
Re: Two stepper z-axis January 16, 2016 03:55PM |
Re: Two stepper z-axis January 16, 2016 06:38PM |
MKSA
Much more expensive, complex and not required. Two lead screws, timing belt and one stepper.Quote
AudaciousTuddle
I will also advocate a closed loop control system, I would love to see a encoder on the motor. That solves all these problems.
Re: Two stepper z-axis January 17, 2016 04:36AM |
Re: Two stepper z-axis January 17, 2016 06:31AM |
Re: Two stepper z-axis January 17, 2016 08:11AM |
DjDemonD
There are designs for 1 motor z axes for the i3 lovely one on thingiverse but a bit complicated [www.thingiverse.com]. I'm working on a super simple one with 2 pullets and a belt. Not sure if one motor without gearing will have enough power but I can substitute in a geared motor. Will post pics when parts arrive.
For what it's worth I think the 2 motors definitely Utley go out of sync over time.
Re: Two stepper z-axis January 17, 2016 09:52AM |
Re: Two stepper z-axis January 18, 2016 07:49AM |
AudaciousTuddle
I would guess that any small discrepancies in alignment manifest themselves as a bed that is not level, and can be fixed by simply leveling the bed.
Re: Two stepper z-axis January 18, 2016 08:34AM |
JamesK
Nope, not that simple. If the X-axis is not square to the Z-axis then everything you print will be out of square to exactly the same extent. For the amount of error that is possible before the Z axis binds up it may or may not matter to you, depending on what you print and what your expectations are.
I used one motor and a belt in a triangle config. No problems with power using a standard nema 17 motor and leadscrews with 8mm pitch.
Re: Two stepper z-axis January 18, 2016 08:54AM |
Re: Two stepper z-axis January 18, 2016 10:53AM |
Re: Two stepper z-axis January 18, 2016 01:36PM |
Re: Two stepper z-axis January 18, 2016 02:07PM |
Re: Two stepper z-axis January 18, 2016 02:11PM |
Re: Two stepper z-axis January 19, 2016 03:16PM |
Re: Two stepper z-axis January 19, 2016 03:22PM |
Re: Two stepper z-axis January 19, 2016 07:47PM |
Re: Two stepper z-axis January 19, 2016 08:23PM |
Re: Two stepper z-axis January 20, 2016 09:51AM |
Re: Two stepper z-axis January 20, 2016 10:06AM |
Re: Two stepper z-axis January 20, 2016 10:11AM |
Re: Two stepper z-axis January 20, 2016 12:53PM |
