Temp sensor
January 16, 2016 10:16AM
I'm only getting 1 print per hot end temp sensor failure.
Running 24v to power the control board, should I power the control board with only 12v ?
Re: Temp sensor
January 16, 2016 02:03PM
Yes
Re: Temp sensor
January 22, 2016 09:36PM
Ok, new hot end sensor, the control board is back to 12v
I'm still getting the error, but it's not every time, sometimes the printer can run for 25 hours (about 4 prints) before getting the min temp error.
other times only 2 prints.
Would I get this error if the hot bed temp gets more than 2 deg below set point ? or is it only for the hot end?
what else should I look at to fix this problem ?
