Hi all,
I finished building my kit and I am on to printing some test cubes. I am having some issues with the stepper motor that feeds the hot end. It often stutters and is unable to pull the material properly. It seemed like a simple case of needing to tweak the voltage but if I do, the motor will feed fine except it has a pretty serious rattle (clearly enough that it will not print cleanly) and makes a lot of noise. If I keep turning the voltage screw on the driver, it will cycle between not having enough strength and the stuttering. Its also running very hot. A few other things i've tried:
-I took the feed assembly/Hot end off of it and ran it manually to ensure that nothing was creating too much friction. Same results even without material in it.
-I tried swapping the stepper driver for the spare that is included in the kit.
Any ideas/suggestions would be greatly appreciated. Thanks!
