Jobs will not print - using Windows 10 February 08, 2016 10:28AM |
Re: Jobs will not print - using Windows 10 February 08, 2016 09:24PM |
Re: Jobs will not print - using Windows 10 February 09, 2016 11:26AM |
Roger123D
what you should have is Repetier Host V0.95F or later it can be downloaded where you found Server and is a different program. I am using Windows 10. You got an SD card and it should have all the files you need or the PDF should have links to those files. Don't erase the SD you have just get a new one everything may be on it. Sounds like the computer isn't connecting to the printer to see this hit the connect upper left in Repetier then it should change to disconnect and if you go over to manual control a bar with show Idle and you should be able to move XYZ turn fan off and on and heat the bed and extruder. You have to match printer/computer baud rates. That stuff is found under Printer Settings upper far right next to Emerg Stop under connection tab and should have a valid port, baud rate mine is 11520 for now,transfer protocal autodetect The LCD on printer shows its baud rate set computer to be same. You may have to go into Windows 10 control panel and set up new printer or go to device manager to find conflicts or add drivers. Best to use manufacture files or you will be setting up far more than you want to and calibrating all the stepper steps Since you have Windows 10 get 3D builder to open STL files although I don't use it. When you decide to make your own things look at AUTODESK 123D free version
Re: Jobs will not print - using Windows 10 February 10, 2016 01:09AM |
Re: Jobs will not print - using Windows 10 February 10, 2016 08:16AM |
Re: Jobs will not print - using Windows 10 February 10, 2016 09:42AM |
Re: Jobs will not print - using Windows 10 February 10, 2016 09:49AM |
Roger123D
When you go back to Repetier site to get Host you can bypass the donation its still free. There is also available a Repetier configuration program. You should be able to go to Windows and add new hardware ie the printer which most likely has all the settings in the Eprom without the SD card I never use my SD card it sits in a drawer. What specific printer and board does it have as I may have drivers as everything that was on my SD card I had from a site before I got my printer which came with firmware loaded. Windows 10 found and installed my printer and then I exported my eprom to a file but can also view my eprom from Repetier. and this has all the steps/mm for the axes etc. I have an Afinibot A3 with Melzi V2 board and drivers are stored in a file on my computer.as well as newest Slic3r and Repetier zip files should you need that work on a 64/32 bit computer running Windows 10.Your last post went to my email consult me there. Also look in device manager in control panel with printer connected to see what it shows. my drivers may work.
Re: Jobs will not print - using Windows 10 February 10, 2016 05:14PM |
Can't connect to the Melzi (FTDI driver problem)
There has been an issue where a FTDI driver update, pushed out through Microsoft update, disables Melzi controllers that have a non-genuine FTDI chip. This chip is used for USB communication, so the board may look like it's working (LED flashing) but doesn't show up correctly, and Arduino IDE/Pronterface can't connect to it.
This thread describes the problem in detail: [hackaday.com]
Apparently, the only way to visually check the chip is described here: [hackaday.com]
There is a thread about it on the reprap forums here: [forums.reprap.org]
There is a work-around for the problem (forcing driver installation, for Windows) here: [forums.reprap.org]
If the chip has been effected by the driver (ie deemed fake), the device PID is set to '0000'. You can check this in the Mac System Profiler, or on Ubuntu open a terminal window, run "lsusb" and it should show a device at "0403:0000". If you use Ubuntu, there is a tool for resetting the device PID correctly: [www.minipwner.com] Then update the FTDI drivers on your machines so it doesn't rebrick the FTDI chip.
Re: Jobs will not print - using Windows 10 February 10, 2016 05:50PM |
Guchion
Ahh, you have a Melzi 1/2 hybrid, often sold as a v3
Have you looked the the can't connect bit on the wiki? Melzi entry on the wiki
Copied here for reference:
Re: Jobs will not print - using Windows 10 February 11, 2016 09:55AM |
Roger123D
Re: Jobs will not print - using Windows 10 February 11, 2016 09:56AM |
Guchion
Re: Jobs will not print - using Windows 10 February 11, 2016 12:28PM |
Re: Jobs will not print - using Windows 10 February 11, 2016 12:35PM |
Guchion
Normally speaking the setting set by the software for temperatures override the firmware, this is certainly the case with Cura and printrun and Marlin firmware, i doubt it is different for repetier if that is actually what is on the board.
When it stops heating, does the printer still respond or does it hard lock the printer?
Do you have a fan blowing on the print head?
Like the wiki mentions some melzi boards don't get on with their thermistors, so if you have a way of confirming the temp other than that I would, last thing you want is a bad thermal reading causing your printer to over heat and melt!
What worries me is if the printer thinks it is stuck at 167 then it may just keep heating until bad things happen.
Re: Jobs will not print - using Windows 10 February 11, 2016 10:23PM |
Re: Jobs will not print - using Windows 10 February 12, 2016 10:08AM |
Roger123D
When you are connected to the computer forget about the LCD display leave it at printer ready don't set any temps there All the print,printer and filament settings are done through the slicing program before compiling. In my case Slic3r (not Repetier) are used to set filament diameter and temperature settings and a mess of other settings you eventually learn to change as needed. What you do need is a digital inch/metric caliper to measure sizes like filament diameter. As far as the temperature goes it is possible that the thermistor is loose in the hot end and not making good contact with heater block OR the small heater cartridge is loose in the mounting block in essence just heating air not the actual nozzle and never reaches 190 etc set point in which case it won't start printing. Under that gold tape around the nozzle is the heater cartridge that has a small set screw hex socket make sure its tight as it holds the heater in place. I totally rebuilt my MK8 with a larger set screw, heat sink grease on heater and siliconed thermistor in now it works good. The first thing to print is a 20 mm test cube and see how it looks and measures. good luck
Re: Jobs will not print - using Windows 10 February 12, 2016 09:29PM |
Re: Jobs will not print - using Windows 10 February 12, 2016 10:08PM |
Roger123D
Well if nozzle is clogged the extruder should have been clicking like mad and after 30 minutes wore a hole in the filament. If nozzle was to high it should have a glob of filament melted around it and a pile of squiggly filament somewhere. Heat it up to 200 again and push the filament in and it should come out the nozzle then pull it and it should come out with a melted string of filament on the end. Welcome to the world of 3d printing. Other causes extruder needs calibrating, bed needs leveling, extruder stepper needs amp adjustment or nozzle is clogged, tension on extruder gear too weak. To rebuild extruder search on youtube for how to videos before trying.I am assuming you had a valid STL file loaded and sliced when you ran it. you should have the log settings highlighted and running then you can see problems.Also we need to know what extruder you have
Re: Jobs will not print - using Windows 10 February 12, 2016 11:26PM |
