OK, so how bad is this printer exactly? February 14, 2016 07:39AM |
Re: OK, so how bad is this printer exactly? February 14, 2016 08:01AM |
Re: OK, so how bad is this printer exactly? February 14, 2016 10:37AM |
Re: OK, so how bad is this printer exactly? February 14, 2016 11:19AM |
Re: OK, so how bad is this printer exactly? February 14, 2016 06:36PM |
Re: OK, so how bad is this printer exactly? February 14, 2016 07:29PM |
Re: OK, so how bad is this printer exactly? February 14, 2016 08:49PM |
David J
The basic structure seems to be made of plywood - not ideal for rigidity. Also, although it says origin is in the UK, everything else tells me it's of Chinese origin.
Anonymous User
Re: OK, so how bad is this printer exactly? February 15, 2016 03:50AM |
Re: OK, so how bad is this printer exactly? February 15, 2016 08:15AM |
Re: OK, so how bad is this printer exactly? February 15, 2016 06:23PM |
Re: OK, so how bad is this printer exactly? February 16, 2016 08:43AM |
Re: OK, so how bad is this printer exactly? February 16, 2016 09:39AM |
wombat
Thank you all for all the opinions - I really appreciate them.
I think I went though all the cheap printers on Aliexpress and decided to go for this one:
[www.aliexpress.com]
My reasoning:
- steel frame
- auto leveling (the question is how well it really works...)
- decent build volume
- bowden extruder (potentially a good thing?)
- it is not totally unknown 'brand' and apparently assembly instructions are half decent
Any thoughts?
Re: OK, so how bad is this printer exactly? February 17, 2016 02:55PM |
Re: OK, so how bad is this printer exactly? February 17, 2016 09:45PM |
Re: OK, so how bad is this printer exactly? February 27, 2016 04:34PM |
Re: OK, so how bad is this printer exactly? March 03, 2016 04:17AM |
Re: OK, so how bad is this printer exactly? March 08, 2016 09:41AM |
Re: OK, so how bad is this printer exactly? March 08, 2016 10:50AM |
Re: OK, so how bad is this printer exactly? March 09, 2016 05:10AM |
Re: OK, so how bad is this printer exactly? March 09, 2016 05:32PM |
Re: OK, so how bad is this printer exactly? March 10, 2016 08:14AM |
Re: OK, so how bad is this printer exactly? March 25, 2016 02:47PM |
furbrain
- the thermistors for the extruder and bed are 50k (not 100k) and so read about 20 degrees hotter than they really are. You may need to adjust the temperature in order to get things to print properly. If you see temps of 38-35 degrees at room temperature, you may have this problem. I'll swap these out for proper thermistors when I get a chance.
Re: OK, so how bad is this printer exactly? March 28, 2016 11:08AM |
