Zonestar P802Q - steel Prusa i3, quick impressions February 27, 2016 04:33PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 27, 2016 06:53PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 27, 2016 07:06PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 27, 2016 11:05PM |
Only thing which IR thermometers are good, is metering human temperature. Aluminium reflects IR so much that meters are way off easily. Tape your multimeter temperature probe to plate and see how much the heatbed and plate measurements differ. Even that isn't best way to measure but much better than IR.Quote
wombat
HOWEVER it is a bit of a lie - temperature sensor is placed on the heatbed surface, bellow the aluminium plate. I measured the temperature of top aluminium plate using IR meter while printer was indicating 120C and it was only ~75C.
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 28, 2016 07:54AM |
Vuokko
wombat
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 28, 2016 02:32PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 28, 2016 09:34PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 29, 2016 06:54PM |
cobretti
Ask them to send you the source code firmware and use Arduino 1.0.5r2 to update it. If you can't wait, how did you try to update? under windows 8/10 open an administrative command prompt and go to this folder "\P802 Release File\document\9.others\Firmware & tools\Updatetools\AVRUpdataTool. Copy the hex file (P802QAV10.hex) to this folder. You will find the hex file in the "Firmwre HEX" folder. run the batch file called "UpdateFw_melzi" from within the same administrative command prompt window. it will ask for com port number and then the hex file name without .hex and case sensitive if I recall correctly. It should update ok then (had the same type of issue) - the autobed levelling works very well IMO once you have it configured correctly.
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 29, 2016 09:34PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions March 01, 2016 04:41PM |
cobretti
no it is working consistently well - check this [forums.reprap.org] - also read a few more posts after that - I think this may be what you are experiencing. Also suggest you up your power supply voltage to 13.5 - search some of my posts to see a few of my results. attached is my configuration.h with all my adjustments - note i bought the clone e3dv6 hence some of the changes and i did the autotune for my pid values for extruder and hotbed. compare the file to yours...hope that helps
Re: Zonestar P802Q - steel Prusa i3, quick impressions March 07, 2016 10:54AM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions March 07, 2016 11:03AM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions March 08, 2016 09:26PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions March 21, 2016 10:32AM |
Linden
Bought the same printer with auto leveling. Installed the P802NAV20 firmware. Didn't know which one of the five to use. The printer started to auto level (on 3 positions out of 6) next to the bed. Printed a new support plate for the auto level sensor like in the instruction video. Now it is on the left side of the front cooling fan and this is working perfect...
Linden
All is working fine except there is some rattling noise starting to appear from or some bearing or the Y-axe motor.
Re: Zonestar P802Q - steel Prusa i3, quick impressions April 11, 2016 08:44PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions April 17, 2016 07:23PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions June 06, 2016 03:02PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions June 21, 2016 09:50PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions June 27, 2016 10:31PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions July 06, 2016 04:43PM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions November 01, 2016 12:45AM |
Re: Zonestar P802Q - steel Prusa i3, quick impressions February 23, 2017 05:39AM |
