at first glance id say over extruding and too cold.
When i get new filament i always print a test piece Normally a 20 X 20 square hollow that 100mm high as it prints and assuming PLA i start to 200 deg then reduce by 5 deg every 6 mm height ( sometimes mark the height where i change with a felt tipped pen)
If you model is hollow you could pretty much do the same to find the best temp for that filament
good luck
