TEVO Tarantula - The new king of kits March 10, 2016 02:26AM |
Re: TEVO Tarantula - The new king of kits March 10, 2016 11:02AM |
Re: TEVO Tarantula - The new king of kits March 10, 2016 11:48PM |
Re: TEVO Tarantula - The new king of kits March 11, 2016 05:49AM |
Re: TEVO Tarantula - The new king of kits March 12, 2016 05:58AM |
Re: TEVO Tarantula - The new king of kits March 12, 2016 09:23AM |
The Mechanic
How smooth is the Z-axis with only 1 screw?
Re: TEVO Tarantula - The new king of kits March 14, 2016 03:24AM |
Re: TEVO Tarantula - The new king of kits March 17, 2016 03:20PM |
i calculated and need about 5 printers to run my projects faster
Re: TEVO Tarantula - The new king of kits March 17, 2016 03:51PM |
The Mighty Gorgonion
Hi, im new to 3d printing . I started with a prussa i3 acrylic frame geetech. I aim to upgrade it to aluminum frame but i will need in the future a few more printers proceed with my work flow. Im happy with the geetech so far even with the acrylic frame.So here is my question : i saw this model and i really like it is it worth it compare to the aluminum frame prussa i3 geetech or compare to hephestos and form those models what is more stable from the basic models and less parts that need replacement after usage .I hope my question is clear thanks in advancei calculated and need about 5 printers to run my projects faster
Re: TEVO Tarantula - The new king of kits March 17, 2016 07:43PM |
Re: TEVO Tarantula - The new king of kits March 17, 2016 07:51PM |
UltiFix
Is the bowden extruder working out well? What kind of board is it? The z is working well with only 1 motor?
Re: TEVO Tarantula - The new king of kits March 17, 2016 10:05PM |
I currently have a folger 2020, how much of a time difference in assembly was the taranutla vs the folger?Quote
CheopisIV
UltiFix
The printer is working fantastic. The board is an MKS all in one and I'm running Marlin on it rather than the default Repetier Firmware they ship with.
Re: TEVO Tarantula - The new king of kits March 17, 2016 11:24PM |
Re: TEVO Tarantula - The new king of kits March 18, 2016 06:15AM |
.I was thinking to go fro the aluminum frame for it (the geetech) but then i saw this and i thought this might be better if you have any other model suggestion feel free to share also i have the feeling the rods are more durable and from that more precise or not? .Thanks for the respond i hope when i finish my project i can share it here i hope il have my work shop up and running this year.|
Anonymous User
Re: TEVO Tarantula - The new king of kits March 18, 2016 04:53PM |
Re: TEVO Tarantula - The new king of kits March 18, 2016 08:33PM |
MKSA
The X axis is hanging from one lead screw plus a flexible coupler then motor isn't ?
As for the bed, can you try to put let's say 100g on one corner and measure the deflection with a micrometer ? How much ? When I see the narrow track, I think about the way the police ask to walk to check if you are sober
ANd they still use smooth idler pulleys !
PS: linear ball bearing guides are easily damaged by poor installation, improper guide rods, improper lubrication. Plastic wheels because of their elasticity can tolerate poor alignement and their bigger ball bearings won't give up.
Anonymous User
Re: TEVO Tarantula - The new king of kits March 19, 2016 01:50AM |
CheopisIV
X-Axis is a single motor, leadscrew and coupler. So far I get more precise prints and zero Z axis drift or wobble. Compared to my Folger Tech i3 2020s, this one is more capable of precision fitting parts without manipulating settings in S3D.
I have no deflection on the plate as tightened the springs down a lot. They are huge and I thought it would wobble or vibrate but give enough tension and there's no movement. When do you have 100G weights sitting on your print bed btw??
Idlers are smooth, again I don't see the issue here as long as the belts are tensioned properly. No different than running them on bearings like most kits which are also smooth.
Yeah, you could nick the wheels if not built properly, but you can damage anything is not built properly. The benefit I can see of these type over the plastic wheels I used on my Deltas is these are perfectly silent. Slippage and wear...yet to be determined
Re: TEVO Tarantula - The new king of kits March 19, 2016 10:16AM |
Anonymous User
Re: TEVO Tarantula - The new king of kits March 19, 2016 10:53AM |
CheopisIV
None of those are questions, just opinions and I did answer the Y-plate deflection (none). Of course I can push on it and make it move but that's no different than anything else.
I didn't design it so don't care whether people think it's good or bad; I bought, built and tuned one of them and found it to be an excellent kit at a ridiculously low price. It outshines my other production machines that I've been running commercially since July last year. I have them tuned up as well, but they took a lot more attention than this one has so far. Granted, I've only had the Tarantula for a couple weeks and issues could crop up, but so far I'd say anyone with any kind fo technical savvy could get this one running with minimal fuss.
Anyone interested in the kit should also look for and joint the Facebook group. It's an active bunch and those guys are incredibly helpful. Other people who built the kit have had other issues that you can see there.
Re: TEVO Tarantula - The new king of kits March 19, 2016 03:15PM |
Re: TEVO Tarantula - The new king of kits March 21, 2016 09:57AM |
CheopisIV
Take the review for what it is... I bought the kit, built and tuned it and expressed my opinions on the process related to the 6 other kits I've built; nothing 'flamboyant' about anything but your trolling.
If you want to discuss design flaws then by all means get in touch with the guy selling them because I'm not interested as I don't sell them. He's quick to respond when contacted and seems open to suggestions. He's also active on the Facebook group if you do care to track him down. Now, If you're in the process of designing your own affordable 3D printing kit that adheres to technical and mechanical excellence then by all means let me know. I'd be happy to buy, build and review it as well.
Re: TEVO Tarantula - The new king of kits March 21, 2016 10:13AM |
Re: TEVO Tarantula - The new king of kits March 21, 2016 03:19PM |
CheopisIV
I don;t use autoleveling on any of my machines except the Delta. After playing with that I might look into doing it up though, it's pretty slick! One of the Facebook Group Members did up an Autolevel setup guide in PDF, I'll link it here;
[www.sigilpickups.com]
I've been printing off some parts for my next project (Mosly Printed CNC) and have found I'm limited to ~65mm print speeds. The Y-Axis isn't an issue but the Z-Axis wobbles back and forth quite a bit when going over 70mm/s but mostly just the first 6 layers then settles down. I'm going to replace the little internal 'L' connectors with something more robust and see if it improved. Truth be told, I stripped some of the little nubs on them before realizing the Allan key (included) was the wrong size so it might just need some of those.
Re: TEVO Tarantula - The new king of kits March 31, 2016 12:21AM |
tjnamtiw
CheopisIV
Thanks for the info on the autolevel feature on the Tarantula. They simply plug it in in place of the Z limit switch, as usual, but for servo type or the BLTOUCH, you need a servo output as well as the Z limit. Both servo and BLTOUCH allow you to use a glass plate printing surface without the hassle of trying to place a metal sheet below it. It makes it much simpler.
Re: TEVO Tarantula - The new king of kits April 01, 2016 07:47PM |
Anonymous User
Re: TEVO Tarantula - The new king of kits April 02, 2016 08:37AM |
Re: TEVO Tarantula - The new king of kits April 02, 2016 09:19AM |
Re: TEVO Tarantula - The new king of kits April 02, 2016 11:16AM |
tjnamtiw
Since you've turned this string into a blatant advertisement, please tell me why you switched to an 8 mm pitch lead screw and probably quadrupled the load on the Z stepper motor, which was doubled before that by only having one of them? There's proof via pictures of before and after over on the FB user group site.
It looks like a very nice kit but switching such things out means that the buyer really has no idea what he's buying. And Leonardo on the FT site wants a buyer who has a problem with a main board to ship it back to China before you send him a replacement. By my analysis, using USPS Flat Rate Overseas box, that will cost $31.95 plus another $13.95 for registering it, if my memory serves me right. That's about $46 to send a $20 board back!
Re: TEVO Tarantula - The new king of kits April 02, 2016 05:43PM |
CheopisIV
tjnamtiw
Ouch! That doesn't sound right but I've not been active in the FB group recently; too busy printing out the MPCNC from Vicious1.com ... ~150 hours of printing. I think these electronics boards are disposable really, much cheaper to get a new one if the old one goes up in smoke.
I've been doing most of the MPCNC prints on the Tarantula in PETG with awesome results. I've still not had any printing issues on it aside from those I pointed out in the review. That said, I'm trading the Tarantula to a friend for his Folgertech kit which he's having trouble getting done up. I built my printer bench to the size of the FT machines as that's all I had when I made it; the Tarantula has a 23" long footprint with the V-Slot and I have a 19" table top. Originally I was going to sell the FT machines and outfit the den with Tarantulas but then I'd have to change the whole workspace again which doesn't make sense.
In the end, they both print the same quality and are both amazing kits. Next up is to finish the Mega Delta and get the MPCNC running. It also looks like making a multihead MPCNC into a ginormous 3D printer isn't too big a stretch so might be something to consider....
Re: TEVO Tarantula - The new king of kits April 02, 2016 07:29PM |
