Xok
Hesine M505 (China Prusa I3 copy) - how to config LCD in Marlin?
March 17, 2016 02:59PM
Hi all!
I bought Hesine M505 (Prusa I3), Melzi 2.0 board and strange LCD screen 20x4 with 5 buttons.
I can't configure Marlin to work with this LCD. Strange two white lines on this LCD and no more text. But i can connect with printer using Repetier-Host and i can control exitruder and move them.
Can anyone help me with configuration Marlin for this strange LCD?
Re: Hesine M505 (China Prusa I3 copy) - how to config LCD in Marlin?
March 18, 2016 09:45AM
I am having the same problem as you. I tried to update the firmware to a "working update" from someone on Thingiverse and the screen is now solid blue with white bars.
I came across a forum with a solution for the 5 button LCD. Someone made this firmware: [www.dropbox.com]
It works for the LCD display but it's not printing properly anymore. I think the configuration of the machine is totally different. I'm not an expert but I think the ZAXIS_STEPS_PER_MM is set wrong for our machine (Anet A8-B by Hesine)
Hope this gets us in the right direction.
March 18, 2016 03:35PM
Someone from another forum - P802M posted this info. This might help.
minhtri.sm
The leadscrew Zonestar3D has was pitch 2mm but number of start is 4 that mean its pitch = 4*2 = 8mm so step is 400
Some use the leadscrew that pitch 2mm too but number of start is 1 that mean its pitch = 2*1 = 2mm so step is 1600
The GT2 Pully is 16 tooth so step is 100,
Some use GT2 20 tooths so step is 80
Xok
March 19, 2016 02:27PM
I draw schematic of this LCD to understand how it work )))
Screen - simple HD44780
Keys - on one line with resistors.
Wiring notes:
1 - GND
2 - NC - Ext_A4 - Pin33 - PA4
3 - RS - Ext_A3 - Pin34 - PA3
4 - E - Ext_A2 - Pin35 - PA2
5 - Buttons - Ext_A1 - Pin36 - PA1
10 - VCC
9 - D4 - Ext_RX1 - Pin11 - PD2
8 - D5 - Ext_TX1 - Pin12 - PD3
7 - D6 - Ext_SCL - Pin19 - PC0
6 - D7 - Ext_SDA - Pin20 - PC1
March 28, 2016 01:53AM
can you send me the working firmware ti install on RAMPS 1.4 board. I do not have an LCD. i am using pronterface and slicer. please send quickly
Xok
March 28, 2016 02:35AM
Hesine_m505 - original firmware from china seller.
Marlin... - my compiled version.
Connection speed 115200 for Hesine firmware.
My printer based on Melzi board, i not sure is it work on RAMPS.
Edited 2 time(s). Last edit at 03/28/2016 02:42AM by Xok.
open | download - Hesine_m505.hex (360 KB)
open | download - Marlin.ino.sanguino.hex (218.3 KB)
April 09, 2016 12:11PM
Hello. this is true even for Anet V1.0? Thank you
Edited 1 time(s). Last edit at 04/09/2016 12:12PM by pavel3.0.9.
