Z axis - gaps between layers April 27, 2016 09:57AM |
Re: Z axis - gaps between layers April 27, 2016 03:35PM |
Re: Z axis - gaps between layers April 27, 2016 11:51PM |
Re: Z axis - gaps between layers April 28, 2016 04:51PM |
Re: Z axis - gaps between layers April 28, 2016 11:57PM |
ss002d6252
Thanks guys
Hmm , it appears to be an extrusion issue.
No matter what esteps value I change to (via marlin - and checked with pronterface & repetier to make sure it is updating) the extruder pushes though around 180mm for every 100mm it's asked to. It's off - I've checked the board and everything seems ok on that.
I also seem to be getting the occasional knocking noise from the extruder.
Craig
Re: Z axis - gaps between layers April 29, 2016 12:14PM |
hoxsiew
ss002d6252
Thanks guys
Craig
If you have eeprom enabled, be sure and clear it out. I spent several hours trying to tune my machine only to find that a value I'd previously stored in eeprom was overwriting my attempts to change params in the firmware. I ended up disabling the eeprom in marlin since it is easier to just flash new firmware values than to tune via eeprom.
Re: Z axis - gaps between layers May 01, 2016 09:54AM |
