moving up (hopefully) Max Micron Alum frame.. May 25, 2016 08:25AM |
hopefully have it in a week or 2.. only been without the M3D for 12 hours and already jonesing to print something LOL
Re: moving up (hopefully) Max Micron Alum frame.. May 28, 2016 08:09AM |
I'll find out when it gets here I guess...
Re: moving up (hopefully) Max Micron Alum frame.. May 31, 2016 01:07PM |
Re: moving up (hopefully) Max Micron Alum frame.. May 31, 2016 05:30PM |
Re: moving up (hopefully) Max Micron Alum frame.. May 31, 2016 08:53PM |
Re: moving up (hopefully) Max Micron Alum frame.. June 01, 2016 05:38PM |
Re: moving up (hopefully) Max Micron Alum frame.. June 02, 2016 07:14PM |
it's ALIVE!!!! June 03, 2016 12:34PM |
Re: it's ALIVE!!!! June 03, 2016 05:28PM |
Re: moving up (hopefully) Max Micron Alum frame.. June 05, 2016 02:34PM |
Re: it's ALIVE!!!! June 07, 2016 03:41PM |
Re: it's ALIVE!!!! June 09, 2016 03:10PM |
Re: it's ALIVE!!!! September 17, 2016 11:15AM |
Re: it's ALIVE!!!! September 17, 2016 11:46AM |
Re: moving up (hopefully) Max Micron Alum frame.. September 18, 2016 08:58AM |
Re: it's ALIVE!!!! September 20, 2016 07:42PM |
Re: it's ALIVE!!!! September 21, 2016 04:53AM |
ShooterT
Thanks guys, great info. Just got her all wired up. Powered up and all axis motors work. Of course I found my first cracked part... one of those nice shiny acrylic plates at the top of the Z axis. Ugh, I'll probably glue and clamp it for now until I can find / figure out how to design one. I'm going to double check everything, level the bed, set the autoleveling sensor before I proceed.
Re: it's ALIVE!!!! September 21, 2016 07:37AM |
Re: it's ALIVE!!!! September 22, 2016 09:05AM |
Re: it's ALIVE!!!! September 22, 2016 01:03PM |
ShooterT
As far as the Z support goes, how should I print it? On its side? I'm using the slicer that came on the SD card if that helps.
Thanks again for your help, slowly learning...
but worth it.|
Re: moving up (hopefully) Max Micron Alum frame.. September 22, 2016 06:28PM |
Re: moving up (hopefully) Max Micron Alum frame.. September 22, 2016 06:46PM |
Re: moving up (hopefully) Max Micron Alum frame.. September 22, 2016 06:59PM |
Re: moving up (hopefully) Max Micron Alum frame.. September 22, 2016 07:01PM |
ya. Did a bunch at 100%. Kinda a waste... 1mm+ shell with a 50% infill at times can actually be stronger.Quote
ShooterT
Ooh, ok... So the 13 hr 100% fill .1 was excessive on my part? I'm using Cura 15.x.x ( newest of the 15). I've been printing from the SD card because I can't get Win 10 to print yet. Light flashes on the board, but nothing happens. I'll deal with that later.
The part will be done soon, looks great so far!
Re: moving up (hopefully) Max Micron Alum frame.. September 23, 2016 10:05AM |
Re: moving up (hopefully) Max Micron Alum frame.. September 23, 2016 12:02PM |
Re: moving up (hopefully) Max Micron Alum frame.. September 24, 2016 12:23PM |
Re: moving up (hopefully) Max Micron Alum frame.. September 24, 2016 03:28PM |
DaGameFace
Step 1. Remove stepper drivers (WITH POWER OFF)
Step 2. jumper all pins as such in picture
Step 3. add a *16 after all your steps per mm settings in firmware and increase acceleration
Step 5. Profit! from the now musical sound of your smooth stepper motors
This is assuming your stepper drivers are fairly standard ones that are 1/16 max. A pretty safe assumption seeing you got it from a kit. There are ones with 1/32 max but havent seen those included in a kit.
Re: moving up (hopefully) Max Micron Alum frame.. September 24, 2016 07:54PM |
Re: moving up (hopefully) Max Micron Alum frame.. September 24, 2016 08:05PM |
