Blobbing
May 31, 2016 05:59AM
I have a problem printing from PC because printer breaks when print circle and that makes blobbing.
But that happends only when printing from PC, when printing from SD card directly it is ok.
What can be wrong???
Re: Blobbing
May 31, 2016 08:46AM
If the circle has to many segments the printer can empty its buffer and momentarily stop while it waits for more data from the pc. This is slower than loading from SD
check you baud rate is 250000
make sure to use an few segments as possible while still giving you good results
