1 layer in Cura
Posted by TommyF
1 layer in Cura
June 10, 2016 02:57AM
I use a paper to set (BQ iprusa3, printhead 0.4mm) to bed, about 0.2mm
So the first layer should be around 0.2mm high,,
Is that the value i input in Cure software (1 layer) or is this calculate in the program?
Second, the press also means that 1 layer is abit wide ie a square 20x20 will have a 20,4 in layer 1 and rest layers up is fine around 20,15...
How to remove 1 layer extra wide course by the press(stick to build plate)
BQ I3 prusa - PLA
