Calibrating problem
Posted by iuliu
Calibrating problem
June 23, 2016 02:18PM
Hi guys, this is my first post and I'm kind of a noob, so please be kind smiling smiley
So I just managed to assemble my new Prusa i3 kit (bought off ebay) and I got to the calibrating part. I selected auto home from the lcd controller. X axis homes fine, Y axis homes fine, but when Z axis comes close to the end stopper I get a problem. One stepper motor (the left one (next to control board and X motor) stops short of reaching the end stopper, while the motor on the right keeps on going. Now, as the end stopper is on the left side, it doesn't click, so the stepper motor on the right keeps going.. The left one stops at around 8-10mm off the target. It goes up and then comes down again, but only to stop short again.
Any ideas ?
Thank you.
Re: Calibrating problem
June 25, 2016 10:40PM
Sounds like Z axis steppers are miswired especially if fed by one driver they use a series connection not a parallel double check their wiring
July 03, 2016 11:37AM
I think the Z stepper wiring depends on the board. I know with RAMPS there are 2 connectors in parallel driven off the same driver plug-in board.
Can you move the stepper down all the way physically with no power applied?
Using the host software can you manually step the Z axis down until the problem area is reached and check for physical alignment issues?
It's possible to have a binding problem on one side.
July 09, 2016 06:42AM
Checked and triple checked wiring and connections. Finally I think there was a slight physical misalignment, which I managed to fix somehow.. no idea how smiling smiley . Thanks for the advice guys! smileys with beer
