Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 18, 2016 10:34AM |
Re: Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 18, 2016 11:45AM |
Re: Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 18, 2016 01:52PM |
FA-MAS
The fan for the heatsink of the hotend should be on all the time. It should be wired to 12v directly.
Re: Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 18, 2016 03:51PM |
Re: Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 18, 2016 04:36PM |
Vuokko
What else you have connected? I had similar issues with LCD when Raspberry Pi was connected with USB. When I printed straight from RPi, My LCD was full of garbage and communications timed out frequently. Now my printer gets ground from ATX PSU and RPi USB has some 10 euro Chinese USB isolator. Basically it was ground loop.
Also your PSU might be little bit underrated if it can't heat the hot end. Measure the RAMPS input voltage. And make sure heater is connected securely so that there isn't bad connection in terminals. That will melt them.
Re: Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 18, 2016 05:48PM |
Re: Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 18, 2016 05:51PM |
Veesta
Not sure if i like the crimp you have on the LCD ribbon cables there. Try re seating the LCD connectors on screen and on board. Give the cables "more space" around.
And maybe disconnect the LCD completely and test with Pronterface and USB cable how it works?
Re: Questions regarding E3D V6 hotend fan and Reprap Discount LCD July 19, 2016 09:21AM |
