Hi Folks,
it's happened again...
Symptoms.
See the attached image - the error message displayed is..
def / 190oC def / 50oC
System starts, preheat PLA, level the bed manually, load filament, print file from SD card.
at some point the error occurs and the temperature is no longer controlled, so the bed and extruder stop heating and the extruder stops feeding.
the head keeps moving.
first time I replaced the entire extruder head - seemed to fix it - but doesn't explain why the heat bed also stopped.
second time, I have no spares...
thoughts - is it really the heater head assembly? or is it the control board??? or a software bug?
open |
download -
(46.4 KB)
