the serial ports must match as well as baud rate if using windows go to device manager and look at usb section one should specify the printer and check serial communications settings also look in add new hardware it should detect the printer most likely its a mismatch in baud rates plugging in the printer on a running computer then start printer program and do a connect command will show an error of whats wrong. sometimes if you do a disconnect then reconnect especially from repetier
