Can't print from computer
Posted by pete-c
August 25, 2016 08:05AM
Hi
I have downloaded the drivers and Cura 15.04.06 to my computer but are still unable to print or level as it says it is not connected to the computer.IT shows up as ok on the devices and drivers. Any suggestions would be greatly appreciated.
Regards
Pete
Re: Can't print from computer
October 03, 2016 10:36PM
the serial ports must match as well as baud rate if using windows go to device manager and look at usb section one should specify the printer and check serial communications settings also look in add new hardware it should detect the printer most likely its a mismatch in baud rates plugging in the printer on a running computer then start printer program and do a connect command will show an error of whats wrong. sometimes if you do a disconnect then reconnect especially from repetier
