Infill3D extruder upgrade - Auto Home Issue
Posted by Rokh
September 09, 2016 12:57PM
Hi All,
So I'm new to this forum, but I have had my Hictop 13 around 3 months now and i have slowly been printing upgraded parts along with lots of other random prints.
I have fitted my Infill3d parts all ok.
But for some strange reason the direction of the Auto home has changed and it now moves right instead of left and hitting the mirco switch.
Ive changed nothing, so this is puzzling me, it is like the polarity of the motor has changed.
Is there anything in the setting to change this.
Any help would be amazing.
Thanks
Rokh
Re: Infill3D extruder upgrade - Auto Home Issue
September 11, 2016 07:42PM
Firmware should have setting which way the home is and whether your endstop is MIN or MAX.
Are you really sure the motor polarity has not changed?
It might also be a problem with a connector, but usually the motor just changes direction randomly.
Edited 1 time(s). Last edit at 09/11/2016 07:43PM by Veesta.
September 12, 2016 01:31PM
Flip the X motor connector over.
September 12, 2016 02:15PM
I cant connect my mac to my printer, so cant edit or check the firmware. But ive not changed anything.
I just dont understand why it is doing what it is doing.
Thanks
September 12, 2016 02:16PM
The connectors only connect one way.
September 22, 2016 10:22PM
my install limit switch at wrong position during setting up home axis ... any way to reset home axis or reset the setting without connecting the board to PC
thanks
October 19, 2016 10:08PM
some micro switches have normally open and normally closed connections as well as a common very easy to test limit switches by physically moving the axis by hand to mid travel then initiate a software home for that axis and as it moves press the limit switch and movement should stop otherwise it is a bad switch or incorrect firmware setting. Most limit switches are mechanical but could be optical or even proximity and require different activations
