heatbed connection
October 03, 2016 10:41AM
I'm planning to change my heatbed to an MK3 heatbed, but I have two questions,
on the wiki I saw this "Make sure you are using electrical cable with a proper gauge (14 gauge recommended)" could someone tell me which type of cable I should use (in mm2) ?
Moreover, the MK3 heatbed can be used with wired thermistor or smd thermistor, which is the best to use ?
Thanks a lot.
