Can't set negative Z axis offset
Posted by hiwatt25
October 16, 2016 01:20AM
I finally installed my inductive probe and everything seems to be going well except for setting the negative Z axis offset. The extruder homes like it should and the probe makes its trip around the bed but when it comes time to print, it does lower the hot end the -.35mm I've set in repetier.
I've also tried setting the negative offset in the firmware but still no luck. Is there something I'm missing because everything is working well otherwise. Been working on this for hours, maybe I'm missing something simple and just need to head to bed. Thanks in advance.
Edited 1 time(s). Last edit at 10/16/2016 01:20AM by hiwatt25.
Re: Can't set negative Z axis offset
October 17, 2016 11:06AM
Make sure you have:
#define min_software_endstops false
October 17, 2016 03:37PM
Cool, I'll give that a shot. Thanks.
