Anet A8 doesn't detect sd card. October 17, 2016 12:00PM |
Re: Anet A8 doesn't detect sd card. October 17, 2016 12:30PM |
Re: Anet A8 doesn't detect sd card. October 17, 2016 12:39PM |
Re: Anet A8 doesn't detect sd card. October 17, 2016 12:40PM |
Re: Anet A8 doesn't detect sd card. October 17, 2016 12:44PM |
Supermec
press the centre menu button on the printer and go down the menu until you get to SD Card. Enter it (right button) and go to Unmount SD Card. Enter it and the remove the card. Clean the contacts on the SD card with a cloth. Replace in the socket on the control board, making sure that you press it right down and that it locks down in place. Go to the Menu again and select SD Card. Enter it (right button) and you should then have an option to Mount Card. Enter it (right button). The machine should see the card and the available options should change to show Unmount Card.
You should be now able to use the print file option and select the folder and file using the buttons.
Have you connected the printer to your computer using the USB lead yet? If so, and you have installed the drivers and software (including Repetier Host) as detailed in the PDF file on the SD card under software, then open repetier host and click the connect button. It should connect and see the SD card and read its directories and files which will be displayed in the log file at the bottom of the computer screen.
I'm told that sometimes the printer has problems with the provided cheapo SD Card. They always seem to read alright on a PC. Copy the provided documentation and software etc onto a safe backup directory on your PC, Put the cheapo card away somewhere safe and use a decent quality SD card to transfer files to the printer.
I don't bother to use the card to transfer files unless I want to use the computer while the printer is printing. USB coms on my system is certainly reliable for files up to 2 hours print time. I haven't used it on a longer one yet.
Adrian
Re: Anet A8 doesn't detect sd card. October 17, 2016 12:45PM |
Re: Anet A8 doesn't detect sd card. October 17, 2016 12:50PM |
Supermec
Another message popped up while I was writing mine.
DO NOT be tempted to start playing with configuration files and firmware. The already installed firmware on my Anet A8 worked 100% AOK from the word go. The problem is almost certainly dirty card contacts or dirty socket contacts. Try repeating ejection the card several times.
Also see my post entitled Anet A8 Where I'm at. You will find some comments in there that may be usefull.
Adrian
Re: Anet A8 doesn't detect sd card. October 17, 2016 02:18PM |
Re: Anet A8 doesn't detect sd card. October 17, 2016 03:08PM |
