Today I thought I would give my old printer a shot.
First time firing it up all went well bed was heating up and hot end was too but I had to shut it down since I remembered to adjust my z end switch. So after trying to heat up the bed it won't heat up and the led which indicated that heat bed was heating is always off.
- It is showing correct temperatures in my LCD so the termistor I don't think is the problem
- Measured the voltage on bed, is 0
- Hot end seems to heat up fine, only the bed doesn't
Printer:
- Prusa I3 rework
- MK2 heat bed looks like
- 12v 33A power supply
Added my
Configuration.h file in case there might be something in there I have set wrong.
